Diy bandsaw fence suggestions?
jorp_porp
Kalamazoo, MI
14" taiwanese delta knockoff didn't come with a fence. Anyone have suggestions for a DIY solution? Simple or complicated, taking all solutions.
J
jorp_porp
Kalamazoo, MI
Simplest is a board and a c-clamp. From there, the sky is the limit. I've adapted a fence from an old import table saw. The nicer ones I see have a better rail and clamp, about like you'd find on a table saw.
I do have some spare C clamps and a drill press clamp. Seems like I'd need some sort of rail on the board to keep it squared up
Firebrick43
West central Indiana
This guy has a lot of info to build your own guide rail system, or purchase parts or whole system from him? Lots of good ideas.
This is 1 of 3 of his band saw videos.
I know his band saw is large, just sharing ideas
MushCreek
Upstate South Carolina
I need a simple fence for my 14" Delta. I normally don't need one, as I have a table saw, but I do use the Delta for resawing thick stuff. The underside of the table isn't shaped well for clamping.
J
jorp_porp
Kalamazoo, MI
That was my though as well - resawing. I'm not sure my saw is capable of any heavy resawing, but I know i'd like to give it a shot
milkovich
Akron Ohio
I used these t-track nuts and knobs to make a resaw fence. One thing to note, it's nice to have adjustability in the fence because every blade will kind of wander in it's own direction. I'd love to give it the full "snodgrass" every blade change, but I guess I'm lazy. FWIW, this is an 11 amp craftsman 14" and while it won't set any records, I can resaw 6-7" of hardwood with a 3-4 tpi blade. bandsaw.jpeg
Many people suggest a single point fence for resawing, so you can adjust the angle of cut on the fly. I've never tried it that way, I use a sled.
J
jorp_porp
Kalamazoo, MI
Nice! That's a good price on those t track nuts. I've 3d printed some in the past and they work all right with threaded inserts and/or captive nuts.
Does the sled work well?
y'sguy
Tulsa, Oklahoma
Oof, this thread reminds me that I need to spend time adjusting the track of my bandsaw. I know there is a good method for this on an older Craftsman saw. I have seen some in the past, but they have newer more modern adjustments
How long is your sled?
Just big enough to be handled by one person, unless the log is too big. Two people works well. 36" for the base, the log part might be a bit shorter.
I like it. Made a few errors building it, like not setting the edge of the sled to the blade, to make measurements of the slice easier. Stole some ideas from a commercially available kit.
Here are some pic of the build and options it can handle, and in use
So you are more sawing logs than resawing dried lumber into thinner sections
I think there was taking dried log shaped objects into thinner sections on the sled (better wood holding into vertical vs hand held). Nothing green was cut on my saw yet. I have a different blade for green wood that is still a virgin, tho probably rusty bu now.
But we also took some lumber into veneer pieces, or guitar backs, without the sled.
More pix of those events here
And here
