falcongarage
- Joined
- Aug 2, 2012
- Messages
- 24
After building quite a few CNC plasma tables over the last few years I saw a need for a different kind of table. Something above a pure DIY project, but still really economical to simple to build. Something that a lot of the members here and on a few other forums like the HAMB and Grassroots Motorsports would be possibly interested in.
In addition being affordable it needed to meet the following criteria:
A proven design that had all of the key engineering details sorted out - parts dimensions, cut lengths, drive systems, water pan, etc
A table that was compact enough to fit in just about any garage - 2'x4'
A table that could be built with primarily off the shelf parts - everything is available locally or through ebay
And most importantly, simple enough for the average hot rod guy to be able to build - proven easily "buildable" design
The machine I designed to meet these criteria is finished and up and running! Cut results rival most machines in the $10k range.
The table was fully developed in a 3d modelling environment first and then built in my garage with average tools to prove the design and assembly was feasible. A plan set was generated from the 3d model and is now available including the key engineered parts laser cut. This table can work with many different plasma cutters such as Hypertherm, Miller, Lincoln, Thermal Dynamics, Everlast, Longevity and many others with the correct specs.
If you are thinking about building a cnc plasma table, but not really sure which way to go, check out my new website and see if this direction could be what you are looking for.
www.hotrodfab.com
Pierre
www.hotrodfab.com
Pierre
