DIY Economizer for Garage?
HoosierBuddy
Southern Indiana
Hey guys,
Recently we've had some summer weather. Typical day here in southern Indiana is seeing highs in the low 90's and lows about 70. My 3 car attached garage gets pretty oppressive and stays that way. The 3 ton ac for the bonus room above (also cools attached breezeway) has been running most of the time and during the heat of the day is unable to hold temperature upstairs in the bonus room.
Part of the issue is the garage gets hot and just stays hot. Even when I go out there in the morning when its 70 degrees outside it's pushing 90 in the garage.
The garage is 2X6 contruction R-19 walls. The garage ceiling/bonus room floor is insulated as well....but I have noticed the bonus room AC struggles much less if the garage is cooler so I've started opening all the doors while I have my morning coffee to get some air exchange. I have to close them when I leave for work though.
Soooo.....the garage has 3 rather large operable windows. My concept would be to use 2 of them, one in the south west corner and one in the north east corner, to mount fans. One would be set to intake, one to exhaust. Here's what one looks like:
I can't find CFH, but they are 4 speed 25 watts with a reversible motor for intake or exhaust. They include adjustable thermostatic control, but that's based on room temperature.
Strategy would be to plug them into a temperature controlled outlet that would power up when the exterior temperature dropped below maybe 78 degrees. Then leave the fans' interior t-stat setting at say 65 degrees. So, in the summer they would run any time the exterior temperature drops below 78 (normally about 2 AM here lately) and would keep running until temperature got back about 78 outside (normally about 11:00 am lately)
Using those style fans, total cost would be about $250.
I could opt for cheaper versions of the fans (without interior t-stat control) and get it done for more like $125. Actually for summer use, the interior t-stat isn't really needed anyway.
Anyone have experience with this sort of thing? Seems like it should work, but as always, any feedback you can provide is appreciated!
larry4406
Northern Virginia
Not sure on the fans, but seems helpful.
Attic truss on top of garage? If so, how is the back side of the kneewalls sealed off? Should be sealed off with Thermoply or similar. Old school was just to leave the batt exposed. This allows convective currents to occur and encourage heat transfer.
Are kneewalls blocked solid at bonus room baseboard level? If not, huge leakage path.
My prior bonus room had these sins. Once fixed, much nicer temps.
dcg9381
Austin, TX
Those fans directly, no... But I've got a 3-car with a bonus room above it, the room doesn't cover the entire garage area, so I installed an "attic fan" on a thermostat that will fire up if cars heat-soak the garage. It vents out the soffit...
I think your idea is solid.
WisJim
Menomonie, WI
If I was doing this, I would be using some cheap box fans that I see for $10 each at garage sales. Even new, they aren't expensive. For the difference in cost you can make available fans fit the windows. Then you could decide if fancier fans would be worth it or if a window AC unit would be better.
Copymutt
Colorado
I regulate home temps here by just manually controling windows. Open at night, close during the day, retired so being on site is ok. Works fine & no huge AC bill. Fortunate that humidity here is single to low double digits. Another approach would be to get that sun off the roof & walls if possible. I’ve measured 148* on the garage SW wall. Even w/ 2x6 R19 it causes heat soak. Soon be ordering shade cloth to cover the patio & that wall outside the garage. Shade cloth rather than an extended roof as I want the solar gain in the winter due to a huge southern window. That will make a huge difference.
That leaves the attic which gets unbearably hot. For all its benefits metal roofing maximizes heat gain. I have end vents but might someday modify the shed design roof to incorporate ridge venting at the top. It helps during site selection to plan for deciduous trees that are natures way of controlling unwanted solar gain.
Firebrick43
West central Indiana
I would run a program on the controller that starts circulating air any time the temp drops say 2 or more degrees from the high in the past 4 hours AND the inside temp is higher than the outside temp.
I think if you wait till 78 degrees outside temp you may already be behind the eight ball in cooling it down.
I would then shut off the fan if at any point the inside temp rises more than say 2 degrees past 6am. It would be counterproductive to let them run till 78 degrees.
I have been thinking of doing the same thing but with an AC infinity cloudline duct fan
H
HoosierBuddy
Southern Indiana
I appreciate the feedback guys.
I'm certain those that suggest a window AC are correct in that it would work better, but it also uses a magnitude greater (or more) power.
I found a cheaper/higher flow window fan and a couple of slightly less expensive digital temperature controllers with 2 meter corded temp sensors I can use for control. The equipment is supposed to be here Wednesday.
This morning when I got up it was 64 degrees outside and 82 degrees in my garage. I hope that with the proper fan control, I could see closer to a 2 or 3 degree differential in the morning (67 in the garage in today's example). Once the outside temperature gets above say about 74, the fans will shut off and my 6-inch insulated walls will help keep it cool....where right now they are just holding the heat inside.
We'll see. I'll post back on this thread on the results.
H
HoosierBuddy
Southern Indiana
OP, have you seen these? I know nothing about them but someone shared it with me as I could end up being in a similar situation. Don't know if they are reliable.
Thanks. If I was going to cool this with ac, I'd go ahead and install a minisplit. In fact, I may do that yet.
As I said before, the $450 power bill Duke sent me last month has kind of got me thinking "How can I use less power" vs more. So for now, I'm just using fans.
Fav Onefour
MN cold and hot
I like the idea of doing night time temp purging. With my garage, it's a manual process without any active air movement. I have found that the toughest nights are when both vehicles are parked hot. The vehicles bring a lot of heat and without exchanging air the whole garage mass heats.
On a side note, I also noticed a change with an insulated slab. The garage walls and ceiling were already insulated for years before I redid the slab. The insulated slab heats up with the garage more than plain old concrete did. I've gone around with an IR temp gun and the slab temp is the same as wall and ceiling. I'm not getting as much ground temp cool down. It's not a huge deal but it creates a different scenario. Before slab insulation I had a big heat sink that didn't come up to ambient temp. With insulation, the slab mass struggles to counter the heat from parking hot vehicles.
@HoosierBuddy , take some temp readings of the slab and walls right as you pull the vehicles in at night. The readings are probably not that hot. I bet you can help alleviate some heat by using the fans to get vehicle heat out before the whole building mass heats. Overnight cooling would have more success if it had less heat to overcome.
H
HoosierBuddy
Southern Indiana
Good points.
My slab is insulated as well due to the hydronic heating system for the garage. That likely exacerbates my summer issues.
Denwood
Thunder Bay, Ontario, Canada
Good points.
I have done significant work and testing with regard to automation and night cooling. I did this with my commercial building using automated 2nd storey clerestory windows and a 2000 CFM exhaust fan on the main floor. It worked well and at times would allow AC in the building to hold off until 1-2pm. The building was 9000 square feet and heavily retro-fitted.
1. You need to move a lot of air, think more like 800 CFM.
2. The intake fan if left unfiltered will coat the interior with dust.
3. Humidity is always a challenge so the automation system compared inside and outside temps, as well as looking at humidity as decision points.
4. Overcooling was an issue, particularly in the tenant areas under the clerestory windows, so I had to add some logic to stop this.
I would look at using fans like the AC infinity 8 or 10 inch ECM inline units as they move a lot of air and use comparatively little power. Connected to louvered dampers, they are easier openings to secure. I control ECM fans like these using 0-10V dimmers in my automation system, however they do have bundled controllers that can control the fans based on temp and humidity. I would use two, one for exhaust and one for intake and build a filter box to take a 5” 16x24 or larger filter in the MErV 8 range.
This is pretty much plug and play: https://acinfinity.com/airlift-t10-...3jw6AOMdLHeKfzDyj1KodCUVlMHriPbst5j-QOKPQxxYj
54 watts at 631 CFM
For testing, two box fans in opposite windows (one for intake and one for exhaust) should give you an idea of effectiveness. CFM on these fans will plummet when you add filtration but test them bare for a few nights.
jshillin
PA
I'd bite the bullet and go ahead and install a mini split. The amount of electricity it uses should be negligible due to cutting down on the run time for your upstairs unit and not adding the fans.
