DIY Epoxy floor recommendations
matt74
I need help with a epoxy floor. Concrete is being poured tomorrow with a slick finish and no sealer. I want to epoxy the floor myself. Any recommendation on which epoxy kit?
rjacobs
Dallas, TX
I did Legacy Nohr-S myself, well my wife I did it.
We only did partial flake, but looks like they only offer full flake kits now.
2 solid days of work between grinding and putting down the primer coat and then coming back the next day to put down the color, flake and clear. 4 years later its still in great shape.
FJ4FUN
NorCal
To begin with, your new slab will need to cure for a minimum of 29 days before any coating.
We offer a number of high build 100% solids industrial epoxy systems to the DIY community, you can check them out here: AlphaGarage Kits
For some recent customer experiences check these out, you can learn a lot from these projects:
400sf CFLC
Partial flake floor
Novah Jones
I’ve used Rust-Oleum EpoxyShield for a few DIY epoxy projects, and it’s been a solid choice. It’s easy to apply, gives a smooth, durable finish, and has held up well in high-traffic areas like my garage. One thing I’d recommend is prepping the surface properly—etch the concrete to ensure good adhesion, and apply in the right temperature (50°F to 90°F) for best results. The kit includes everything you need, and the results have always been professional-looking. Definitely worth considering if you're tackling the project yourself!
mattthemuppet
San Antonio TX/ Spartanburg SC
I used Armorpoxy. Screwed up the flake (me being a dingus) but it all came out very well and I'm much happier with a single colour. It seems pretty robust, though it doesn't like heavy pointy things or weld splatter being dropped on it.
Andy Smith Jr.
Houston, TX
Several good options here from vendors in the group :
Both are epoxy based, which is better then a poly base IMO.
jcacavias
Atlanta
Another vote for armorpoxy. I'm coming up on a year with my full flake floor and it's been bulletproof.
