I saw your post about adding insulation to your garage door but there were no pictures added. I would like to do the same and my doors are like yours and you cannot push the insulation into the squares. I would like to see how you did it and do you have any pointers you could give to prevent me from making any mistakes.
Thanks
Amizon
Amizon, I guess my original pics have been lost to the ether. I'll try to get a couple pics this week and post something recent.
My doors had a kind of natural lip on the inside, if I remember correctly. I used a blob of foam-friendly construction adhesive (about the size of a quarter) in each corner of the individual panels. They almost friction-fit inside, but I wanted to know they were stuck in place with all the movement.
Also take note that garage door springs are fairly finely tuned (if they're done right) and even just adding a few light foam panels can potentially throw off their balance. I have been lucky, but a neighbour of mine who did the same thing had his spring snap a while ago, which is a huge pain, and can be dangerous.
***ACTUALLY: check the link in my sig (OJ's single) and you can see a pic of the door.
See I am trying to determine if I should use the foam foil backed insulation or the Reflectix. I'm in Central Texas so our version of cold is somewhat wimpy compared to the Canucks. Of course I want it to stay warm when I get heat in there, but I'm more worried about the heat 100 + days of 100_+ heat and humidity in the summer... (Once I add the AC unit). I'm not sure which would provide more of a heat barrier.
rpcraft, I'm not sure which would be better, but check the R-value of each solution, see if you can roughly compare the weight and cost of each, and I'd go with the overall lightest/cheapest/best insulator combination.
