Getting in trouble...
OmniWall for above workbench and ProSlat for small partition wall ordered. With luck, I'll get to put some up the weekend of the 19th. Will need to split the slatwall. Was thinking 4'x4'. But 3'x4' and 5'x4' may fit the space better. Regardless, the trusty Diablo carbide-tipped 80 tooth laminate & aluminum blade on the DWE7491RS should be up to the task. To date, it's been amazing on RaceDeck, 3/4" laminated Acacia, 2x6 Redwood, 2x3 and 2x4 Fir, 1 1/8" sheathing, 1/2" ply in Hickory, Maple and Birch, 1/16" aluminum, and probably a couple other things. Cuts very straight, and only gives me grief when I'm using the wrong technique - or wrong guide. A little slow on the 1.125, but I can't fault it for that. That stuff is Beast - and I hope I never need to handle it again.
