Ststephen7
I'm sure there is a ton of knowledge here, and I need some thoughts...
I'm trying to make a living making things out of my garage/basement. My big money maker is a welded stainless steel Mjolnir. Thanks to the new Avengers movie I just got orders for 3 of them, and I'm just finishing up a custom one with a 3' handle. I've made quite a few of them now, and have most of it down.
However... for the handle I cut pieces of leather to match the curvature of the rings I make (I made a little die from some black pipe), and then I sew the pieces into rings that slide onto the handle...
If I'm making a hammer every couple of months it's no problem to trace out each piece of leather, cut it out, and maybe use the dremel to match it perfectly to the rings on either side of it.
Now... I have A LOT of these leather rings to make!
If you've every seen clothing parts cut, or leather parts for jackets or shoes cut, you've seen people putting (what I'm calling) a shaped punch on the material, and then a press pushes it through the material, giving a very consistent part.
Has anyone every made themselves on of these? And do you guys have any thoughts about how I might go about making one of these? The leather is a bit over 1/8" thick.
I'll attach pictures of the little pattern I trace, and the piece cut out. I'd like to get one perfect, and then be able to reproduce (near) perfect copies.
I have a pretty limited amount of power metal working tools. I have a small hand held plasma torch, oxy/accet torch, mig and Tig welders, a 4x6 metal cutting bandsaw, abrasive cut off saw, and drill press. Everything else I do with hand held grinders, sanders, etc... after making a bunch of the hammers I did come up with a cut list, and now I have someone cut out the parts for me with a cnc laser
Thank you!
Steve
Thank you!
Steve
