Diy oil drain drum
russlaferrera
Central Virginia
I made this out of old Propane tanks and a office chair bottom. I have $15 invested.
dlc
Northwest NC
I just knew there was a good reason to hang onto that old office chair that's been in the basement for 15 yrs. Very creative, I like.
What did you use for the strainer material?
v8garage
Texas
Very nice project. To make the pipe telescope you need to find a pipe that will fit snugly into another pipe. Drill a hole and weld a nut onto the larger (bottom) pipe and put a set screw in it. :)
R
russlaferrera
Central Virginia
Got it at the flea market It's a grease fryer splatter cover, used in the kitchen. Cost $1. Tanks are found discarded.
Had to make a valve removing tool to get the propane fill valve out. Had to strap the tank to a tree to unscrew the valve.
NOTE: propane is heavier than air. You MUST purge the tank upside down to make sure the tank is empty. Or BOOM may happen.
I cut the tank with a chop saw blade, to make the funnel part. A 3/4 pipe may fit into a 1 1/4 pipe (may have to sand a little) Weld a bolt as a stop
I put a drain valve on the bottom of the tank to put the used oil into a transportation jug. The pipe unscrews from the tank. I made a plug with a tire valve to pressurize the tank to get the oil out.
I welded a bolt on the bottom to secure the tank to the chair wheels.
e-tek
Saskatoon, SK
I'm guessing you cut a SECOND tank for the funnel - correct?
Why do you need to pressurize the tank to get the oil out? You mean to get it out faster - correct?
Nice work!!!:bowdown:
R
russlaferrera
Central Virginia
E-TEC, Pressurizing the tank was necessary to remove the drained oil Up into a 5 gallon jug, and the drain is 1/4 pipe. Because the drain would be lower than the fill height of the 5 gallon container. I will use a discarded washing machine water fill hose for this.
Yes you are right on all "your whys" on why I done this build this way.
e-tek
Saskatoon, SK
Me too. As soon as I finsih my Challenger, engine test stand, spray can shaker, press and...finish testing my "Canadian Maple Syrup" condom - I recruited a CFL cheerleading team who have completed first tests. Verdict : "Yummy!!"
