RickP
I'll bet it's a sycamore tree (we call them buttonwoods too).splotchy green/tan bark
The knots didn't really look like a tulip tree, and I think the mottled bark really points to a sycamore.
Well, I just looked up sycamore tree on the internet and neither the bark nor wood match what this is. The bark is not splotchy green/tan. The bark on this reminded me of hickory - darker gray, almost black, with strips of bark curling up. However the bark appearance may have been affected by how long this tree had been dead or by whatever killed it. Good suggestions. I tried the only tree book I have, but the bark illustrations in it are almost worthless - book relys mostly on leaves and blooms/seed pods/nuts.I'll bet it's a sycamore tree (we call them buttonwoods too).
The first trees I cleared from my 5 acres were all the Locust trees - due to the thorns. I know some Locust trees do not have bad thorns, but as far as I can tell they are not native to this area. Also, this wood is not as hard as the Locust wood I have cut. I have had sweet gum trees on a former property and have never seen any of their seed pods anywhere on this property.You're right -- that doesn't look like sycamore bark.
I've cut a couple of black locust trees that look a bit like those boards. Was the wood really hard when you were cutting it? The only thing is, that bark doesn't look like it has furrows that are deep enough.
Do you remember if the tree dropped any thorny seed pods? The wood also looks a bit like a sweet gum tree, but those thorny gum balls are impossible to forget...
If it was silver maple, there should be volunteer silver maples about.The first trees I cleared from my 5 acres were all the Locust trees - due to the thorns. I know some Locust trees do not have bad thorns, but as far as I can tell they are not native to this area. Also, this wood is not as hard as the Locust wood I have cut. I have had sweet gum trees on a former property and have never seen any of their seed pods anywhere on this property.
So far, I have reviewed 59 species and think there are only 3 likely possibilities - Western Soapberry, Hop Hornbeam, and Yellow Poplar (the Poplar is supposedly not native to this area). Bitternut Hickory, Silver Maple, and Sugarberry are less likely possibilities. Can't figure out (yet) any step to take to further narrow it down.
Of those 3, I've only seen yellow poplar. I cut a lot of it for firewood (I call it a tulip tree). For a hardwood tree, the wood is actually pretty soft. But it does look like your photos of the milled boards; did they cut like soft pine? The tulip bark is really distinctive with its inner bark -- very stringy and wet when cut, and falling off the trunk when aged. That doesn't sound like a good match to your bark though?So far, I have reviewed 59 species and think there are only 3 likely possibilities - Western Soapberry, Hop Hornbeam, and Yellow Poplar (the Poplar is supposedly not native to this area).
Since yellow poplar or tulip tree is supposedly not native to this area and since I have never seen any blooms on any tree on my property like those associated with tulip trees, I consider it very unlikely. Of course, I have identified a Buckthorn Bumelia tree on this property which is not listed on the native trees list put out by OSU. Which, is why I am stuck.Of those 3, I've only seen yellow poplar. I cut a lot of it for firewood (I call it a tulip tree). For a hardwood tree, the wood is actually pretty soft. But it does look like your photos of the milled boards; did they cut like soft pine? The tulip bark is really distinctive with its inner bark -- very stringy and wet when cut, and falling off the trunk when aged. That doesn't sound like a good match to your bark though?
I was really lucky on the truck/key issue. I spent several seconds wishing I had a coat hanger before I started looking for alternatives. I still can't quite believe the branch worked - apparently there was enough of a bump or high enough coefficient of friction to hold the carabiner while I raised the keys up about 18" and rotated them to where I could grab them off the stick.Always nice to hear from you. Clever solution to the locked truck problem. What did you win?
Those are some good suggestions. I have a tool similar to the F&M scraper that I used to get a corner of the carpet up and pop the tiles. I plan to try it first to remove the glue. If it does not work, I plan to try scraper blades on my oscillating saw next. Then, I may be tool shopping. I have also considered trying a wire brush on my 4.5" angle grinder.I am hesitant to suggest options, given your excellent skills. In case this might be helpful. . . You might look at some floor scrapers like these. I have one similar to the first one for the shop to scrape dried epoxy / paint spills off the floor. For a project like yours I'd try the air scraper. Just because I am old.
Plans A-B-C-D. I like it. One of those should work!Those are some good suggestions. I have a tool similar to the F&M scraper that I used to get a corner of the carpet up and pop the tiles. I plan to try it first to remove the glue. If it does not work, I plan to try scraper blades on my oscillating saw next. Then, I may be tool shopping. I have also considered trying a wire brush on my 4.5" angle grinder.
