Hey guys,
We just bought a 100 yr old Tudor house. There is a detached 18x18 garage in the backyard, but on the opposite side of the driveway. The seller removed the driveway leading up to the garage to pick up green space and the garage functions as storage.
The town and house are both historical, so I cannot demo or relocate, or even rebuild the garage this close to the lot line. Additionally, the town is highly taxed with sensitive reassessment. the taxman becomes almost the number one decision as to what renovations to make and how to make the construction process not so in your face. He could jack up the annual tax bill by a few grand without hesitation. I want to do as much work myself as possible, and try my best to rehab the existing structure.
Any regards, I will be converting the garage to a multi functional space. Basically a nice rustic existing interior with glass doors plus barn doors, and an oversized side window. Occasional car storage in winter, and open up for large family events in the summer.
The garage needs slab rehab, new electrical, a new roof, and new doors and windows. I would like to do the slab, drainage, front stone apron, and interior myself. Then have a contractor do the electrical, roof, and doors/Windows.
Slab
The slab in cracked and separated. The current design of the slab was to be sloped towards the center, with a center drain. The drain hole is basically just a circular opening filled with dirt and looks to have been inoperable for a generation or so. Within a 5 foot radius of the drain, the concrete cracks and dips down into a "basin" that is sunken about 3 inches. Basically a 10x10 foot area that is as low as 3" below grade at center. The slab is relatively thin and rests on dirt. There is no water build up, except for the far front of the garage but that is due to poor drainage. I do not want to tear up the slab and start new. While the concrete is thin and slightly flexes if jumped on, it does feel to be fully settled.
Could I fill in the sunken "basin" area with mesh and concrete, blend it. Then repair other cracks. When that is all done, I could epoxy over for a smoother look? Or even add planked wood on top. Would that work? Or a near impossible job for one man to fill a 10x10 3" basin with concrete by bucket mixing?
Garage Door
The door gets stuck 90 percent of the time if manually opening. You need to lean into it, and then open. It's an old wood door that will be demod. However, it makes me think that The garage may be off square. I took general dimensions and took a leveler to the edges and at first blush, it seems close to level. Most of the wood framing has been reinforced, which leads me to believe someone squared up the garage, but that could have been 50 years ago, not sure.
Any recommendations for how to see if the garage is square, and how to adjust?
Any manufacturer reccs for swing out wood and glass double doors? Something that looks like a French door, but could fit a single car through with no bottom door jamb?
Thanks boys!
Slab
Garage Door
Thanks boys!
