DIY Stackable banana jacks disassembly
Jay870
May need to turn my man card in.
Is there a trick to getting these things apart? Got one pried open with a couple of small flatheads but kind of mangled it in the process.
No idea why the don't ship these disassembled.
niget2002
Josephine, TX
You sure it dissassembles? I have some that the outer plastic stays on to keep from accidentally shorting things. The barrel it plugs into fits between the banana and the outer plastic protective part.
J
Jay870
Yeah these are setup to solder the wire into the banana plug like below.
niget2002
Josephine, TX
Yeah. Those look like they'd **** to take apart.
Little bitty screwdrivers to push in the tabs. I'd probably clamp the round part in a small vise so I could pull the big part while pushing in the clips.
cgrutt
Looks like you might be able to get a pair of bent needlenose pliers and release tabs one side at a time. (I'm assuming there are notches and tabs on both sides of the connector).
J
Jay870
About 30 seconds with the heat gun and slipping couple of small flat heads into the seam on each side separated them without any damage. Still... they should just ship them as parts.
