jimgood
I've wanted to do my own alignments for some time but didn't want to spend stupid money for the tools. I've looked at lots of string alignment DIY videos and blogs. There are lots of ways to do this.
My criteria for the string holding tool are the following:
My plan was to connect 1" aluminum tubing together to form a framework that hangs at each end of the car and supports a long tube to which the strings are tied. I searched for tubing connectors but could only find very expensive options. Then Ed Higgenbotham at Grassroots Motorsports pointed me to 8020.net and their Quick Frame Connectors. They turned out to be just the trick.
I only had a rough idea in my head of what I wanted so I ordered:
Part Qty Price
9330 4 $56.00
9250 8 $20.80
9220 4 $10.40
Subtotal: $87.20
Shipping & Handling: $19.07
Tax: $0.00
Grand Total (Incl.Tax): $106.27
I also got 4 - 1" sq. x 96" aluminum tubes with .065" wall thickness from the big box store at just over $16 each. So we're at about $170 all in.
I ordered 8 of the 9250 3-way corner connectors but I really should have only ordered 6 of those and then 6 of the 2-way corner connectors. They're the same price so it doesn't matter much.
Here's the finished front frame. I'll use C-clamps to secure the long horizontal bar after the strings are attached and it is adjusted to the proper height.
View media item 84880
Here's a side view of the front frame assembly with all of the parts marked out. I'm not providing dimensions because they are specific to my car and wouldn't be of any use to someone trying to build one; even the same model car.
9220 are the 2-way corner connectors (90 degree elbow). In the front frame, I only used one pair as the "hook" that hangs the frame on the front fascia of the car. 9250 are the 3-way connectors. I used these to connect the outer vertical parts of the frame and the cross bars. I could have substituted 2-way connectors at the bottom; again, not a big deal as they're the same cost. 9330 slides over the vertical tubes and the extra nub sticking out is what I'm using to support the string bar. Straight from the factory, they're a very tight fit. I used a very sharp 1" wood chisel to shave off some material on the inside so they weren't so tight. I went a little too far on one but it will do.
View media item 84896
The rear frame is basically the same though I needed some tubing on the "hook" at the top of the trunk.
View media item 84892
Not as cheap as simply tying string to jack stands but I think this will work out a little easier. I should be able to set this up once and have it be the correct height, only needing slight side to side adjustment. This could have been done for less than half the cost if I was competent at welding aluminum (and even cheaper if I'd made it from steel).
I'll try doing the alignment this weekend. I just replaced my rear trailing arm bushings so I know the rear toe has to be adjusted. The front has felt okay but I noticed uneven wear in all four tires on the inside. Goal is 0 toe in both the front and rear.
- Attaches to the car so that the string remains aligned when rolling the car back and forth after a toe adjustment.
- Light weight
- Easy to build
- As compact as possible but I don't want to break it down or set it up every time I want to use it
Part Qty Price
9330 4 $56.00
9250 8 $20.80
9220 4 $10.40
Subtotal: $87.20
Tax: $0.00
Brilliant! Just brilliant.
