BorisMD
Hi all,
I was looking around at wheel dollies, and anything that looked reasonably priced looked like cheap you know what. So, I figured I'd make my own. I mostly wanted them to place a '59 Corvette that I am going to restore on, so that I could move it around more easily.
I started by locating casters that would work well. That seems to be the limiting factor. I found a fellow on ebay who sells all manner of casters, and emailed him. He cut me a deal on sixteen of them. They are very heavy duty yet have nice non-marring wheels. They have grease ******* on the axle and on the raceway.
I then decided to use 3/4" plywood for the platform. I cut pieces 12x18 inches, and glued two together with construction adhesive, and nailed them with my trim nailer.
After than, I drilled the holes, and attached the casters with hardware ordered from boltsonline.com. The quantity I needed for this made the online order more cost effective than buying them locally.
In retrospect, I wish I would have bolted them right after gluing the plywood together, as the bolts compressed the plywood much tighter than my spring clamps.
I also think that going with plywood slightly larger would work better -- perhaps 18x24. In addition, it may make sense to add a 2x2 on each end to keep the wheel centered.
The cost was around 170 for casters and 47 for hardware (with shipping on both).
Here are some photos:
Clean smooth floors == easy movement.
