DN Flange to ANSI??
NWill
Columbus, Ohio
All,
I am trying to go from a 3" MNPT fitting, to a DN80 PN10 flanged valve, to a tri clamp. The valve should have Tri Clamps on both ends for quick disconnect.
The valve is only available with DN80 PN10 flange.
The 3" MNPT cannot be changed.
I have searched for hours an cannot find a good combination of BSPP/BSPT/NPT/DN/ANSI, etc adapters.
For reference:
DN80 = 160mm bolt circle.
ANSI 150 = 152.4mm bolt circle.
I prefer not to modify the valve body.
Lastly, the valve is cast aluminum and the cluster of parts will be 304 or 316SS
So finally, anyone know where to source a DN80 to tri clamp, a DN80 to FNPT, or DN80 to BSPT with a BSPT tri clamp to thread.
Or, who can make me DN80 to FNPT Flanges :)
Attached is a quick drawing of a few options.
Thanks!!!
pancho400cid
Austin, TX
Looks like you already though of tapping a blind flange.... that's one option, depending on the situation (not great from a "streamlining" perspective).
You can get a stainless DN80 weld-neck flange. If they make a tri-clamp flange that is weld-neck type, you'd just have to weld them together. I don't know anything about tri-clamp and what's available. Or you can buy a tri-clamp adapter or pipe stub-out, cut off the not-needed end with left-over length to suit, machine a bevel prep on it and weld that.
Obviously the welder / weld would have to meet the required classifications, certs etc.
dr_clyde
Holland, MI
If it was me, I'd get blank flanges, bore them to fit a 3" TC heavy wall ferrule, then weld them in. Then you can get a 3" TC x NPT adapter and you're on your way.
Steel and O'Brien had a lot of odd adapters and fittings. VNE also has a large catalog of all these kind of parts. You may need a distributor for some of this stuff. Most off the shelf parts that are ready made I buy from the Galloup branch of the Kendall group in Grand Rapids. I don't know if they deal as far south as Ohio, but I bet they'll ship.
kbs2244
I would check the cost of a catalog item against a local fab shop.
N
NWill
Columbus, Ohio
Thanks for the tips!
I figure I have two options. Find a DN80 flange and weld in a tri clamp.
or
Get a 150# flange and slot the holes a bit.
I'm going for option two first. I ordered a 304L SS 3" NPT 150# flange to play with.
Who can give me some tips on milling these out? I only have a mill drill so keep that in mind. I have limited experience on my mill and none with stainless. Any help is appreciated.
N
NWill
Columbus, Ohio
I was trying to avoid welding. And this way appears to be more economical unless someone knows a good source for those DN fittings. I'm around $92 for a 150# flange and 3" NPT to Tri Clamp fitting.
