Do I have a water problem?
jbass350z
I live in the desert, yet I seem to have signs of water seeping through the concrete. Is that what is going on in the attached images?. Moonsoons do hit us pretty hard once a year. If it is water stains, what are my options here? I was wanting to lay down Hellfire or Polyurea.
Second question: how do I handle the 4 inch painted lip that goes around my entire garage? Stripping that seems near impossible, or at least an insane amount of labor to do it, but I would like to coat that also.
BillK
Beautiful Southern Maryland
The second picture almost looks like something was spilled and ran down to the left. How long have you been in the house ? Has the floor always looked like that ?
The lip looks like wood ? I dont know if you can use the coating on that. I would just paint it.
benwah
Crested Butte, Colorado
Sometimes in the desert water tables are higher than you think, Arizona for example. You could try running a fan over a spot for a day or two, and see if the moisture goes away then comes back after you turn the fan off.
You could also just sand the trim well, vacuum, and apply 2 coats of a 100% Acrylic paint, or 2 coats of the epoxy/polyurethane you plan to use. Test an area first
mikehart
Iowa
I would go to a local supply store and get some moisture tests. Basic ones are not that expensive. Here is a link to some great articles: Be Floored Blog. How old is the concrete? I would start with the moisture tests and go from there
