Do I need 3/8" sockets?
jipps
UK
So, my main tool use is homeowner and working on my cars, motorcycle, mower etc. I have a comprehensive set of 1/4" ratchets and sockets, and a comprehensive set of 1/2" ratchets and sockets. These already overlap on sizes etc, so I have no "blind spot." I have some (a fairly ragtag and incomplete mix) of 3/8"... flexhead ratchet, torque wrench, and a get-you-through selection of shallow sockets and impact sockets.
So, should I invest in a decent 3/8" set?
50% of me says absolutely, it will become my go-to set. The other 50% of me says, it won't do anything that my 1/4" and 1/2" set can do, except let me use my 3/8" torque wrench without steppers.
Do I go 3/8 or not? :dunno:
General Geoff
Allentown, Pennsylvania
I've found I use 1/4" and 1/2" far more often than 3/8". The only thing I end up using 3/8" for is spark plugs (because the plug sockets only come in 3/8"-drive), and junk yard runs where I want to just take one drive size. And I do have two complete 3/8" socket sets (metric and SAE) and multiple ratchets.
Beenman
Pretoria, South Africa
Yes.
For years I used only 1/4" or 1/2" as that was all that was available in SA (we follow European trends). Then I purchased a Koken 3/8" set this year after some threads on this Board convinced me. Best thing I ever did socket wise.
Can't recall when last I used my 1/2" while working on an engine in a car. The 3/8" is strong enough for almost all bolts, yet compact enough to fit where my 1/2" could never dream of. I keep the 1/2" though for suspension or sub-frame type bolts.
shoggoth80
Seattle
I use 1/4" and 3/8" more than 1/2". Aside from impact use, or really needing to ream on something... it's 1/4", 3/8", or I jump to 3/4" drive.
Edit: The answer is yes, from my point of view.
softailgarage
Bullhead City, Az.
You'll use that 3/8 set alot more than the 1/2" set, I guarantee it.Unless your working on a big engine or piece of equipment, 1/2" is just too big. Besides, this gives you another excuse to buy more tools.
Danglerb
SoCal
This ^^^^^
I use 1/4 for most stuff, bump up as needed for more torque.
Most of the time, I have some ratchet I prefer and use what fits that.
When you aren't sure you need it, easiest way to find up is to buy a cheap set and see if you use it, then upgrade as needed.
Bondo
Greenfield, Maine
Ayuh,..... I'm a Mechanic by trade, 3/8" is my go-to set,....
1/4" rarely gets used, 'n 1/2" is only for big bolts on big iron,...
cowboy73
southern Indiana
I use 3/8" on almost everything. I typically use the 1/2" on larger stuff like suspension components. 1/4" is used mainly on small engines and on the interior of vehicles.
Qualitytools
SOCAL
Yes buy a 3/8 set it will become your go too set. It will fit in a lot more places than the 1/2 and is a lot more robust than the 1/4. You won't regret it :)
fatfillup
Finksburg, Md
I don't think questions like this should be allowed on this forum:lol_hitti
More tools is always the answer:lol:
You should probably have a 3/4 set too but 1 inch may be overkill:D
bonneyman
Desert SW
Since I was a teenager a 3/8" socket set was all I had. Since I don't do HD truck repairs a 1/2" set wasn't needed, and I didn't move into a huge set of 1/4" stuff until I got into appliance repair.
Get a quality 3/8" set (like S-k) - you won't regret it.
PJNJ
Iowa
Back in the '70s when I started buying tools, the local hardware store was the main "go to" for tools. My local hardware stocked a lot of SK and most of it was in 3/8's with some in 1/4 and a lesser amount in 1/2. So I started with 3/8 and that has been my main go to for decades. Smaller, lighter work - 1/4. Heavier such as suspension - 1/2. But the majority of the time I can get all of my work done with a 3/8 set since a good set has large spread of most used sizes. I'd look at SK or Gearwrench for a good set.
:beer:
If you were just starting your collection, I would have said, skip the 1/2". Mine RARELY get used. I have more 3/8" "accessories" (universals, spark plug sockets, extensions) than I have for my 1/4" or 1/2". The only thing I don't have is a breaker bar, because my flex-head ratchet is actually longer !
jonjon1
I think I only use 3/8" lol, Its definitely my go to set, for impact also, and when my 3/8" gun won't do the job I just grab my 1/2" gun with the 3/8" adapter....
3/8 is a no brainer, I even use the 3/8" head ratchet with the 1/4 handle more than an 1/4" ratchet I own..
junk
Paullina, Iowa
Yes. Buy 3/8
I use all pretty equally depending on what I'm doing. I'm surprised you've gotten by without a 3/8 set.
Squddle
I would definately get the 3/8 drive set. I use my 3/8 set for most things, my 1/2 drive set for heavier things where a larger tool can fit, and my 1/4 drive set for smaller stuff and where there's not alot of room.
toolaholic
PA
I actually have a craftsman 1/2 drive spark plug socket. Bought on clearance at Sears hardware for about $3.
Rubiman14
I couldn't imagine life without having 3/8 sockets! With my new 3/8" SO impact, I find myself using 3/8" 99% of the time now
Jure
Croatia
you dont need it,but soon it will become your "go to" drive size.. buy cheap toptul 3/8 set...
greyjasper51
essex, uk
i use 3/8 for everything, lug nuts the lot, the only time i reach for my 1/2 is subframes or drive shaft hub nuts, 1/4 i only use the 6+7 for jubiliee clips, swinging a 1/2 all day can get tiring, 3/8 is my go to set for everything, if that dont budge it then yes i have to go up but 99% of the time car stuff is 3/8 and works perfect
plus space can be an issue sometimes where you cant get torque on a 1/4 and 1/2 doesnt fit well
wagon
calif
Agree with everyone. I never use 1/4" unless it's something really small, or, as previously stated, on interior stuff.
Half inch is for removing my lugs or suspension stuff.
3/8" is the perfect medium between the compactness of 1/4" and the robustness of 1/2". Almost everything can be done with 3/8"
8man
Bryan, Texas
I use 3/8" more than anything else. The 1/4" is too light for most stuff and the 1/2" is too large unless I'm breaking large stuff. The 3/8" allows me the right feel for most stuff.
Get the 3/8" and you will never look back or regret it.
Rico.
England
BDT/NWMN
Erskine, Mn
Tell us about Your 3/8 flex-head ratchet.. If You have ANY 3/8 ratchet that You really enjoy using; those sockets WILL get used.
