I want to build a 18' (gable end) by 28' garage with an 8' ceiling and a 7' by 16' door. For the gable end door can I use a standard (not gable end) truss and just nail a 2x4 ladder under it for the siding? As far as I know the door adds very little weight to a standard truss. Using an end truss means I have to use at least a double 2 by 12 for a header just to hold up the truss.
I have an 18x28 garage and I did a hand cut roof, 2x8 ceiling joists and 2x6 rafters. Gives me lots of storage up there for things like the storage boxes for all the different seasons, christmas, haloween, .... Nothing hugely heavy but a 2x8 at 18' is no problem handling the loads.
I also built a mezzanine about 5' deep at the back of the shop. I used hurricane clips for the rafters where I cut out the joists, the mezz floor is only 3' below the old joists so nothing is going to pull apart. I also build a room below it that I keep heated in the winter for glues, paints, etc. I climb up using a charin (with the box of brava on it) onto a file cabinet, then onto the shoe rack and up ontop of the fridge, makes it easy to stage things to the top of the fridge before moving it up to the mezz.
Wow, that was long winded, here's a pic.
Oh, almost forgot, you NEED a header for the door. Most likely 2x12, its got nothing to do with the truss.
