vavet
One acre lot in a subdivision, about 3/4 acre of mowable grass. My current set up:
Cub cadet riding mower with a 50 inch deck, 25 hp Kohler two cylinder engine, about 10 years old
honda self propelled mower with mulching and bagging capabilities, about 20 years old
ridgid blower and string trimmer (same battery platform for the rest of my power tools)
yesterday was the first mow of the season and a couple things have me considering changing things around.
i tweaked my lower back, i think when i was pull starting the Honda mower. I have a history of back problems, but this is the first time I’ve hurt it in this way
the cub cadet Kohler engine started making some additional noise. It seemed worse with the blade engaged, but it was there regardless. Seems to be coming from one of the valve covers. my son was using it to cut the front yard, so I didn’t notice it until I took it to finish the backyard. I took it to my neighbors house later in the day to compare the noise to his similar mower, but it was not longer making the noise. Maybe it’s only going to do it when it’s hot?
if I opted to go to a zero turn, does that make the walk behind mower obsolete? Can I get close enough to obstacles and tight turns and then finish with the string trimmer?
if the Honda pull starting is the problem, then maybe I just buy a battery powered walk behind. I was thinking that, but the engine noise on the Cub cadet has me concerned that maybe I just need to change everything around.
