Do I need an air regulator? Is my filter adequate?
gsea
I have a 175psi, 25gal, 5.5cfm @90psi cman pro compressor at home for weekend auto work. On 3/8" hose, I run impacts, die grinders, and various detailing and blowing/inflating jobs.
Currently, I am just using the on-compressor regulator and have this little 1/4" Milton filter inline before a 50' hose reel.
3 Questions:
1) Is there any reason to go to a 3/8" setup?
2) Is the on-compressor regulator sufficient or should I add a piggyback regulator and gauge to the filter? If so, do I remove the on-tank reg or just open it all the way up?
3) I have looked around quite a bit and can't seem to find any bracketry for these. Are there any cheap ones available or will I have to make something?
fordbroncodave
if you get a sharpe brand water moisture separator just install it really close to the compressor. it has a regulator and gauge built in as well as a drain ****.
i think you mean you have 1/4" line and looking to upgrade to 3/8"? bigger is better but it can be limiting in tight spaces. also costs lots more and you have to factor in adapters if you need any
pipsters
USA
3 Questions:
My guess is you have the 150 psi 25 gallon compressor, correct?
Like this?
00919541000-1
If so I have the same one. I put a Husky 3/8" regulator on it thinking it would flow more air. What I found out is it actually was a LOT worse. The regulators on the Craftsman pro compressors are actually really good. They flow a lot of air.
Here read thru this:
http://www.garagejournal.com/forum/showthread.php?p=2105640#post2105640
If you were to add another regulator take the one you got off. I am looking into a Norgren as they are a lot better. Also, your filter is OK but maybe look into something in the 3/8" range as they would flow a lot more air. Do you catch any moisture in the filter you currently have? I've been looking at adding one as well.
G
gsea
Sorry, I should have been more clear. I am running 3/8" hose, but this is a "mini" filter with 1/4" NPT threads, so a 3/8" hose will thread right up to it.
Like this?
Almost... this one:
00916778000-1
Milton says it will flow 27cfm, but I'm sure there are caveats to that. It does collect moisture as it is.
