How wide is the span? My pole building is 30" and does not have those. But I don't have your snow load either.
Hopefully you're planning on storing pillows on those "higher end" shelves.Your eye may be drawn to those amazing hanging shelves. I thought you all
might like another.
Here is the "higher end" hanging shelf.
For your viewing pleasure:
-Clint
I'm pretty sure I've read on here a few times that these are not needed and were used when initially installing the trusses.
I don't see what they offer outside that but I'm no expert at any of this.
Thanks
-Clint
, tear that **** down. Possibly the worse craftsmanship I have ever seen.My dad had a pole shed put up 15 or 20 years ago. He was told they keep the wind from racking the structure.
They ARE preventing racking in the direction of the trusses. The diagonal brace opposite the wind direction would be in compression and vice-versa. If they were meant to be temporary, They most likely would have been nailed to the side of the post rather than taking time to place an angle cut on them. Personally, I would add a Simpson A35 angle clip at the brace to post connection and leave them. They may not be 'attractive' but they look better than a building laying flat on the ground. 'FORM FOLLOWS FUNCTION'
I have to respectfully disagree with Lake as to the diagonals being added later by the hideous shelf builder as he could have easily ran the vertical shelf supports up to the trusses and attached them there.
.... If they were not connected to my truss I could pull the board and three nails out with one hand, hell gravity would pull them down?....
-Clint
I'm not an engineer by any stretch, but wouldn't sheathing the gable ends with structural ply strengthen the building significantly?
The engineering is based on the steel sheathing on the building acting as a diaphragm, no need for plywood sheathing from a strength perspective.
I live in farming country and have seen a lot of pole barns. I’ve never seen this type of bracing. Side loading is taken care of by the fact that the poles are buried in the ground. I also agree with you that the few nails attaching the bracing to the upright post isn’t doing much of anything other than holding the brace to the post.
I say...'Kiss my ****' to those that state that toe-nailing is not a good method of connecting lumber!
Take a 2X4 and place two 16D sinker toe-nails on each side, attaching it to another 2X and try to pull the 2X4 off by hand. Toe nailing has much better holding power in withdrawal than end nailing as the angle of the nails in toe-nailing resist each other.
I say "kiss your own ****".
All of the above *****... compared to hangers and structural screws.
The reality is toe nailed wood splits... and over time as the wood dries the strength of the joint decreases.
The problem is the nails are to close to the end of the board.
Toe nailing is not a good way to secure lumber. It’s a temporary or only if there’s no other way type of fastening.
Yeah...what do I know?...32 years of framing experience...I guess I'm a slow learner.![]()
Hey Clint, next time you are out in the barn look to see if the braces are nailed to the lower truss chord also. I'm curious?
Knee Bracing - Used to tie the roof trusses to the posts of the building for additional stability. The knee bracing is nailed to the side of the post and angles up to meet and be nailed to the truss.
Hey Lake,
There are three nails attaching the diagonal to my post and two each in the top and bottom chord of my truss.....
-Clint
