Do I need to build a frame for snap on classic 96 workbench?
stage20
pcola FL
I will be setting an old drafting table base on the top of it and taking the caster's off the box to give me my desired height.
I've searched threads on several hf44 builds that were framed out in steel or wood in preparation for a top
Can the box frame be set on the ground, or should I build a cradle to fit where the caster's were?
For what I will be doing I won't need a cage for the box
csp
Franktown, CO
People build frames to get the boxes at the desired height, not because they need it for support.
stage20
pcola FL
good point. im trying to overthink it. it looks to be reinforced where the casters are. id rather not build a frame, because height is an issue. id hope the outer frame of the box could support its own weight.
csp
Franktown, CO
You could build up some sort of blocking to support the weight in the area that the casters are usually bolted on if it's a concern. Wood is more than adequate.
It's reinforced where the casters are because the weight is concentrated over a smaller area than it would be if the entire bottom of the box were weight bearing.
DHCrocks
Hawaii
is your floor level? might need to shim it up.
other thought is that putting the box directly on the concrete may hasten the rust, with moisture coming off the concrete slab. if you can get by with a little height added maybe just a 1/2" spacer so there can be some air circulation under the box.
stage20
pcola FL
Thanks for the advice there. I'll do some measuring and see what a 2x4 looks like layed down. May have to use some 1 by. Not sure on the lip.
n20junkie
Grand Island, NY
I lay galvanized drip pans on the floor all the time. The bottoms of them are always corroded badly fast.
Don't put anything made of steel directly on concrete, as it will be ruined in short order.
