Can you explain what a proper depth to width ratio means?Water will settle in the cracks. You will notice your control joints (relief cuts) will start to curl up a little on the edge and raise up. Caulk such as Sika or Pecora Dynaflex will help slow this down but not alleviate it.
Basically no real advantage to caulking except to keep dirt out.
Also remember a proper caulk joint has a depth to width ratio you must achieve.
Sure.. Their is usually a ratio called out on spec sheets. Typically 2 to 1 width to depth. See the attached for Sika 1a. The goal is that you don’t caulk a joint that is 2” wide and only 1/8” deep. The sealant would fail rapidly.Can you explain what a proper depth to width ratio means?
Probably a dumb question but certainly related...
Do you east coast guys worry about water filling the crack, freezing, and cracking?
sounds a lot like sikka self level to meI wish I knew what they used at work. Big warehouse, relief joints filled with some sort of gray caulk. It stays somewhat pliable (can push your fingernail into it a little), but handles many years worth of pallets sliding across them, forklifts, pallet jacks, product spills, and a floor scrubber. 3 shifts, 6 days a week.
