I drain the bowl on all of my Honda powered generators. My Eu2000, and GX390 powered blackmax unit. The blackmax unit, I got for free from a neighbor with 1 hour on the hour meter. He put fuel in it back in 2008 for a hurricane, turned off the gas valve, but did not drain the carb, in 2018, he tried to start it, would not start. I tried to clean the carb, and the passages were blocked and the bit of gas in the bowl was like stinky varnish. Since the generator had 1 hour on the meter, I splurged for a Honda OEM carb, ($82 vs $22 knock off) and it fired first pull and runs like a champ. My procedure is run it twice a years, once before and once after hurricane season for a good 20-30 minutes, turn off gas valve and drain the bowl. I try to only run ethanol free in the EU2000.
