Do increasing-size socket adapters (1/4" to 3/8", for ex.) get any use?
hifi_hokie
Hillsborough, NC
Just a quick question. Does anyone have a use for socket adapters that go up in drive size, like 1/4" to 3/8", or 3/8" to 1/2"?
I've seen them on some recommended tool lists before, but it seems like a way to get in trouble by tackling things that really should be handled by a tool in the larger drive size in the first place.
Thanks!
Daz-scotland
Uk
I use 1/4 to 3/8 on my snap on electronic torque wrench for 15mm bolts that need 20nm as I don't have a 1/4 15mm socket. I also quite often use 1/2 to 3/8 on my gun for etorx sockets that need a smaller size but gun power to remove.
tube_guy
I use a 1/4" to 3/8" drive somewhat frequently. Just used one a few days ago when servicing our oil burner for the winter. The nozzles are 5/8" and I use a 1/4" drive torque wrench to set them at 90 inch*pounds. I don't have a 1/4" drive 5/8" socket, so I just use the adapter and a 3/8" drive socket.
bcradio
New Mexico
1/2 to 3/8 is reducing though
jjjrmx5
Cincinnati, OH
I use them all the time.
C'man and Snap-On .
Just depends upon what you need them for.
3/8" drive torque wrench often needs 1/2" adaptor for various wheel bolt torquing or engine work. I didn't spec. the damn M14 and 3/4" bolts. LOLOL
1/2" torque wrench can often need 1/2" to 3/8" reducer to geet what I need.
All depends upon ft/lbs.
Just another tool. Used wrong it will shear or derform. Used correctly it is worth every penny.
YMMV.
Spudland_Dave
Maine
The only one I ever use with regularity is a 1/2" -> 3/4"
From time to time I will use the 1/4" -> 3/8" one on my ratchet screwdriver. 9 times out of 10 the reason I use them is for stupid things like torquing the plastic lug nut covers on my truck (GM Truck Owners will know what I mean), or plastic plugs...large in size but not in torque requirement.
air
1/4 to 3/8 gets used frequently at my house for torque wrench purposes...
ChevyEFI
Phoenix, AZ
I've used all mine at one time or another.
1/2" to 3/4" for hubs
3/8" to 1/2" for pinion nuts
1/4" to 3/8" for when a lighter roto ratchet works best to just spin stuff on.
And on a lighter duty note, I've broken my 3/8" to 1/4".
Heavy Metal Doctor
Mason Dixon Line
Thanks!
It can also be a way to quickly spin some larger fasteners with a smaller drive, especially in a tight space.
kf4zht
Calhoun, GA
I have a few large size sockets that are 3/4" but do not have a 3/4 ratchet or impact so I use the 1/2-3/4.
Also I sometime have a case where a large socket is needed but a low torque reading is needed (ex pinion preload) where my 0-100 in/lb torque wrench only has 1/4 but the socket is 1/2
Or if it is a big nut but a small swing area where you use a smaller ratchet to spin off the nut/bolt.
adam728
Wife's car uses a plastic oil filter housing that requires a 36mm socket and goes back on with 18 ft-lbs of torque. I use the 3/8-drive torque wrench, and an adaptor to the 1/2" drive 36mm socket. While they do make a 3/8 drive 36mm specially for this, I see no reason to bother since I already had the other socket.
marineengineer
Vermont
i use them for all sorts of stuff when there is no spin room or your laying under a machine and cant get the combination to use the socket that fits the drive size. Another time i use them is when i am going to have to use universals and a bunch of extensions to get a bolt off. a smaller ratchet allows you to reach in the place with the correct adapter and apply more torque because of the losses through the angle of the universal. Look on ebay the snap on ones are common and fairly cheap. BUY THEM when you need them there is no substitute for the right tool. That being said my 3/4 to 1in i bought when i had to take apart a hydraulic jack apart. To loosen the big nut on the end (2 7/8) because i do not have the 1 in ratchet. Its not the right tool but i have the long handle older snap on 3/4 drive ratchet and have not broken it yet.
transittech
I use mine almost daily. Mostly so I can use anything bigger than 1" on my 3/8 gun. When you've got 300ft./lbs of torque, not much need for 1/2 guns some days. 'Course, then you get the 7/16 bolts torqued to 1,000 ft/lbs. :eyecrazy:
They're also handy for running a bolt off after break the fastener loose in a tight spot, especially with nylock fasteners.
fatfillup
Finksburg, Md
I use a 1/2 to 3/8 on my 1/2 battery impact as i don't have a 3/8 battery impact.
I also sell a lot of those adapters in all sizes and the big Snappy's tend to sell quickly, 3/4 to 1 and 1 to 3/4 as well as 1/2 to 3/4 and 3/4 to 1/2
ironmutt
Ill.
my 1/4 -3/8 gets used alot on my 1/4 e-impact then my 1/2-3/4-1 cause my 3/4 rachet is is to long to get in some places reducers i use as a last resort when the 1/2 inch impact sockets are to thick or i have to use my three foot ext. for trany work
obsessive
I use 1/4 - 3/8 with spinner handles a lot, especially for torx, for unassembling and reassembling - everything except final tightening when more torque is needed.
t4runner
Lake Grove. NY
In the past I used a 1/2 to 3/4 adapter but I eventually bought a 3/4 drive ratchet from Snap-On [no I dont want to talk about how much it cost it still hurts] I never used any other size adapter
Beaubeau
Sydney, australia
Every day, torque up some spark a plugs with a 1/4 torque wrench need 1/4 to 3/8, use 3/8 to 1/2 for oil filter sizes 24,27,32,36 etc
nanofrog
I use them often enough, particularly the 1/4F to 3/8M for spinning things on/off in sizes that I don't have in 1/4"DR sockets (instead of dedicated nut drivers).
kazlx
Tustin, CA
That's what I use them for. Either a tight space or something that doesn't need much torque to remove. I much prefer to use a smaller ratchet when possible.
BDT/NWMN
Erskine, Mn
For adjusting the injectors on an N14 Cummins, I use a 1/4" drive inch pound dial type torque wrench along with a 1/2" drive socket.. It takes two adapters; a 1/4" to 3/8", and a 3/8" to 1/2".... I have adapters going both ways from 1/4" to 1" drive.... They are used when needed; but not on a reguar basis..
toddacimer
Oshkosh, Wi
I use my 3/8 to 1/2 adapter all the time with my Snap-on MG325 because I have more 1/2 drive impact sockets than 3/8 and the lighter/smaller impact is more convenient
greasemonkey44
memphis
i use 1/4 to 3/8 and a 3/8 to 1/2 for measuring drag on pinion bearings
i used a 1/4 to 3/8 today for knock sensors
and i used a 3/8 to 1/2 to roll over the ls engine i installed; the harmonic balancer bolt is 24mm
i use the 3/8 to 1/2 for alot of oversize but low torque fasteners, like the 36mm iirc for an ecotec timing chain tensioner
Mastermind
Ypsilanti, MI
yes. i use mine once and a while, for many of the same reasons, no 3/4" ratchet, using torx bits that are 3/8" on a 1/4" ratchet.
Acosi151
Atlantic Canada
I carry a 1/4M to 3/8F adapter in my bike tool roll so I can go all the way up to 19mm using nothing more than a 1/4 T handle and a 6" extension.
351-C
I use mine daily to remove/run in bolts on heavy rotating equip. Useful when you have hundreds of sockets, and only one 3/8 air ratchet.
Harwinton
I've got an adapter that I made so I can use 1/4" drive sockets on my 7/16" drive ratchet.
