I often use my manual impact driver for stuck screws. I was just thinking - could work it for bolts too?
The thing is, when you hit it with a screwdriver tip, the downward impact and twisting force are both applied to the stuck screw. If you stick a socket on it instead, the socket often bottoms out before it touches the fastener.
It will still apply twisting force - but not the downward impact (unless hitting the surface your fastener is screwed-into counts). If you had a shallow socket though... then it would bottom out on the fastener and work just like it does for screws.
I realize that's basically the same work "bolt breaker" pneumatic hammer bits are doing. I just figured you could get a similar effect without an air source - if you had the right sockets.
