Do SK swivel sockets have common pin breakage?
JonDick13926
Sidney, Ohio
I broke a 19mm 3/8" drive yesterday. It was my fault. I don't have 1/2" swivel impacts, so I put a 3/8" on one of those Snap On adapters with the replaceable square drive, and attached everything to a fairly new 2235timax. Turned the power up, and four hits in the pin broke into two pieces. I'm going to warranty that one and then get a 1/2" set. These SK sockets seem pretty nice, but I just want to make sure you guys aren't breaking pins left and right before I buy another SK set.
ttpete
Dearborn, MI
Understandable if it wasn't an impact socket. You're lucky that you didn't get the broken piece slung into your teeth.
PJNJ
Iowa
If you use a chrome swivel on a impact, then the pins will most certainly break. Simple solution - Buy impact swivels. Expanding on what ttpete said - I hope you have good medical insurance especially dental if you do that again.
Edit:
After re-reading your original post, I apologize. I thought you used a chrome swivel - my mistake. I would look to pinless for any future impact swivels purchases like the other posters are saying.
:beer:
SMKS
USA, planet Earth
I think the pin is the weak point on any brand of pinned socket. That's why some companies have moved to new pinless designs.
I think I read here that SK is also moving to pinless, but they aren't out yet.
I suspect you would get a similar result with any brand of 3/8 pinned impact getting hammered on a 1/2 impact.
Buckgnarly
VT
I broke a Sunnex the exact same way you did, was a 19mm swivel on a 2235 for clearance issues.... took about 5 turns until it mashed the pin enough that it would not turn.
I would not worry about SKs, they all would break in that case. In the future you probably will be pinless if you have any warranty issues as I to have heard the new SKs will be pinless.
zakmartin
Seattle, WA
Wow. Those ARE nice, but $352.99! :spit:
I've been using the SK swivel impact sockets (the ones in the green cases) for ages and have nothing but good things to say about them. The only time I ever used a chrome tool on an impact gun was when I used a 1/2" chrome extension bar with an impact socket. The chrome changed color and a spiral of hairline cracks worked its way up the bar. I tossed the ruined extension and bought a bunch of new Armstrong impact extensions from Cripe.
I do like those pinless universal joint socket adapters, though. They work SO MUCH better than the ones with the pins in them. I got two 1/2-inch and 3/8-inch pinless u-joint adapters when Craftsman was liquidating one of its stores. They're the USA ones that normally went for about $50 each. I think I paid about $20 each for those. The pin universals never get used anymore.
J
JonDick13926
Sidney, Ohio
Thanks for the replies.
Yes, it was an impact socket. Granted it was stepped up a drive size, which is what I assumed lead to its breaking. I'll get ahold of SK for warranty and ask about the pinless. Ill also look into pinless for 1/2".
