Do they make a metal box like this, but offset 90 degrees?
Skooterj
Indiana
I need a 2 gang, exterior metal box with the conduit entering the top right corner in the side. I can only find 7 opening boxes with top and bottom entry, not side. Or a in use cover I can turn 90 degrees?
Norcal
It is rare to find a Bell Box with hubs on the side but they are out there.
Skooterj
Indiana
What in use cover do you have?
Most can be rotated...
Most 2 gang covers can rotate? I replaced a horizontal 1 gang, but had to use the top corner one the 2 gang sideways because I had another conduit directly above the box. My one gang cover worked horizontal or vertical. My 2 gang does not.
PCustoms
VT
I guess post a pic of what you're doing. The box @mm08822 posted was my first thought but you said top right, that's middle
Not clear what you're trying to do
Skooterj
Indiana
Pretty sure a middle hole will work. Trying to avoid putting even more holes in my siding. Other option is plugged the box on the right and drop the whole thing down an inch.
PCustoms
VT
Don't use the middle hole if you have to have the conduit off kilter.
Simple way would be an LR into the top of the box you have. Probably better solutions out I can't rattle off PN, I have to stand in the aisle and look sometimes
You could also drill a hole lower in that junction box.
Or use an
Skooterj
Indiana
Conduit is a little off kilter already going from horizontal 1 gang to horizontal 7 hole 2 gang. 5 hole probably would have been
be straight.
PCustoms
VT
be straight.
Are you trying to re-use the mounting hole in the siding too?
Skooterj
Indiana
Was trying. Already have an extra hole when I switched out the broken plastic box for a metal one last summer. Decided I needed a 2 gang this summer and was trying not to put a third set of holes in the siding in a small area.
NightSky
Southwest OH
In your original post, the box appears to be square. Can the plates that the devices attach to be removed and installed 90 degrees to the original position so that they are parallel to the blank sides?
Skooterj
Indiana
No. First thing I thought of. I think I found a cover I can rotate.
Intermatic WP1030MXD
PCustoms
VT
Do you really need a dual gang box?
If it were me I'd consolidate everything closer to the junction box, square everything up and put a day of caulk in the old holes and touch-up paint.
Skooterj
Indiana
I need a dual gang because my rechargeable pool vacuum plug covers 2 outlets because it's a stupid big wall wart. So a gang becomes a 1 item. And I use the second one for a cover pump and other assorted stuff throughout the year. Do I "need" it, no. But it will sure be used and convenient.
Skooterj
Indiana
On that note, this is GFCI protected, right?
Yes, at the breaker. Pool installation put GFCI breakers on both the 120 and 240(pool pump) circuit. I piggy backed off the light circuit to add the outlet. I thought about also using a GFCI outlet, but decided it was protected enough.
dave*99
Coastal NJ
If you were considering adding a GFCI outlet to a circuit that is already protected by an upstream GFCI breaker….. don’t.
