Do they make box extenders for ceiling fan bolt spacing boxes?
TT_Vert
Wauconda, IL.
I bought one for a standard 4" box and the bolt spacing is much wider on that. It appears this box is the ceiling fan size with a much narrower bolt spacing. There was a single A19 fixture on this box and I want to extend the box to run conduit to it to feed a couple 4' LED fixtures on the garage ceiling.
I did find one thing but I cannot seem where to get it locally or something similar. I also do not see if they have blank covers for this form factor box.
Thanks in advance.
Dave
bigb56
Tucson, Arizona
Thanks in advance.
Dave
The spacing is the same on all 4/0 boxes, ceiling fan box or not. Sounds like you are trying to come off a 3/0 box, or a 4 square box with a 3/0 mud ring. Use a 3/0 extension with a blank cover. Whatever you do DO NOT hang a fan from this.
T
TT_Vert
Wauconda, IL.
It's not a mud ring to be sure. I'll take a pic of it today. It looks like the octagonal boxes I have been googling up with the screws on the ID of the box rather than the far outside of the corner which probably is why the bolt spacing is different. I will not be using a fan, it is there merely to provide a place to run conduit to to feed a few lights.
Dave
teamextreme
Lakewood, CO
Need a pic. I agree with bigb, spacing is the same for all 4/0 boxes I've ever seen. Only other options are as he mentioned.
