Do you "exercise" your ratchets?
CoThG
Do you regularly spin your rarely used ratchets to keep them free and lubricated even if you don't actually use them to turn a socket?
mikey03
Can’t believe this is even a question here. Of course we exercise the ratchets, after each daily polish you give it exactly 10 rotations each direction and end with the pawl at a 90 degree to the handle. This should go without saying but Bent handle ratchets get the pawl moved to a 45 degree position afterward.
whateg01
doo dah, kansas, usa
Does that apply to flex head? And does the flex head need to be in a specific position? Oh man! I hope I've not been doing it wrong all these years!
bigfunwmu
S. MN
No, but I do spin my torque multiplier a couple times before I torque anything with it.
C
CoThG
no. but I have been given /acquired ratchets that needed to be cleaned & lubed so I call that a win
I have a friend who does not take care of his tools and has a few ratchets that haven't been used in years. I was over at his place recently and he had the rare need to use of of those ratchets and it was nearly seized due to corrosion from being stored in a barn and the lube evaporating away over time. I cleaned and lubed his ratchet and got it back to a usable condition. I told him if he'd regularly function check it by spinning along with replacing dried out lube, this wouldn't happen.
C
CoThG
I park my ratchets with the ball detent at the 12 o'clock position.
lovetap
the last frontier
I have literally never thought about it. I've never had a ratchet not work from sitting in the toolbox. I wouldn't think that grease would evaporate? Pliers sure, they need a workout after some idle time.
kmacht
Connecticut
Don’t forget to rotate your screwdrivers 90 degrees each day. You don’t want one side to become more sun faded than the other and mess up its even grip.
shoggoth80
Seattle
Just use them. They'll get exposed to oils and grease 🤣
Seriously though? No. They'll get oiled or greased every now and again. Non sealed heads will get sprayed with some oil whenever I feel like it.
The only time I've had a ratchet lock up from old grease... Was on acquisition. A good cleaning, and fresh lube fixed that.
neophyte
Pennsylvannia
Isn’t this more of an issue with heat and cold cycles in Ohio, were the temperature gets cold, chilling the tolls, then heats up, causing condensation to form on the tools due to the negative thermal mass of the formerly cold tools, creating a layer of water.
Over time, the repeats of this then cause the tools yo rust, particularly in enclosed areas were water vapor might accumulate?
Add in hot days which will slowly cause lubricants to evaporate, and you wind up with a recipe for rust.
Storing tools in an enclosed container with a desiccant and a VCI corrosion inhibitor would probably be more important.
Some lubricants also attract moisture.
C
CoThG
You are correct. He states that some days when he opens the bay door to his garage, everything is wet with condensation.
...nearly seized due to corrosion from being stored in a barn and the lube evaporating away over time.
As an avid collector of antique and vintage ratchets, I found your question less amusing than most, but your friend neglecting his tools in a barn exposed to the weather are extraordinary conditions compared to most guys and their user toolboxes and tools. I can attest that well over half the antique and vintage ratchets I have found in the wild have been stuck absolutely solid with dried gunk, grease and rust, and taking ratchets apart to clean and re-lube or oil just to get them turning again is a common, frequent hobby activity, but it usually takes several decades of sitting unused in an abandoned toolbox in a garage or basement for that to happen. I don't even spin the museum quality oldies unless I have to get one out for a photo opp or to support a Vintage Tools Discussion forum topic.
LXCam
The toolbox shades mine when stored.
Doesn’t matter. They still will go flat on one side and be out of balance when you go to use them.
Screwdriver lives matter too.
Geez, just came across a Craftsman VM series ratchet, that apparently was not exercising enough. Looking at it at the ES, build up of crud around the plates, probably from powdered jelly donuts every day. It did not want to move either direction. Even with a socket on it, nothing. As I was angling for a bulk price, I just showed grama a pic of my pile, got a $20 price, so I didn't quibble about it.
Got a bit more forceful with it at home, told it I was going to change it's lacksadasical ways, or it was going in the GS pile. Put a bigger socket on it, and threaten to give it a ***** twister, and still nothing. Gave it the TT, upped the force more than normal, and got a click out of it. Some signs of compliance, so I kept twisting. I think the silly thing was enjoying it. A few more twists, each direction, and I think it is salvageable.
It will get a real clean & lube before summer.
See it in the Garage Sale thread later this afternoon.
