Do you have a favorite Soldering Kit?
Wolverine
Ann Arbor, MI USA
I do not have a solder kit yet. Don't want to make any mistakes purchasing....... so, is there a kit that you recommend?????
Much appreciated!
Jared
Victoria B.C
I have an old weller soldering gun and it is excellent if the new ones are as good as the old ones i buy one for sure. As long as you dont buy a cold heat than you should be ok.
Jared
PAToyota
South Central Pennsylvania, USA
I've used one of these for years:
I prefer the trigger to the "constant on" variety. I'm assuming that you mean electrical soldering as opposed to plumbing soldering?
TNToy
West Tennessee
If this is primarily for automotive wire, then get a soldering gun like the one pictured above. They heat up to full temeperature (and cool back off so you can set it on anything) in about 5 seconds.
If you'll have to to detail stuff with it, like re-solder a resistor on a very cramped circuit board, then you'll need a small 15w soldering iron as well.
Neither one will cost you very much money. ;)
ron in sc
Charleston, SC
I have the Weller shown above.
If I had to buy another I'd probably buy a harbor freight model, for $12.99.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=4328
There's a lot of stuff I would not buy Chinese, but for something like a soldering gun I would. I have a harbor freight heat gun which cost $10. It lasted about 2 years and then stopped working probably because I dropped it a number of times but for $10 I can deal with that; I just bought another.
mikeatrpi
Home
I use an inexpensive 15-20w iron from Radio Shack on my circuits, but a gun like above is best for any wiring over 16 ga... IE- a car!
KeukaDan
Finger Lakes Region of NY
Wolverine said:
Yes, the 'gun'-type is the kit I'm referring to.
I have an older Weller gun that I picked up at a farm auction for 5 bucks. I would highly recommend that for most crude soldering. I also have multiple Weller irons along with some cheap irons but when it comes to real electronic soldering I much prefer my Weller Solder Station and my Hakko solder station. The solder stations control heat much more accurately and have much more power to get good solder joints.
