fnieto
All lines pressurized, tank pressurized. End of day, main ball valve off and power off.
auto drains when in use.
I only use and drain mine about once a week. I Always shut it off when I'm done using it, but pretty much always leave air in it. I don't have fancy shop lines, just a 25' hose on a 21 gallon upright. Its nice not having to run it at all if I just need to top off tires or use the air nozzle for a second.
Funny story. At some point I forgot to turn it off after working. Our back bedroom wall is a garage wall, and at 3 or 4am one time we hear this noise. After about 30 seconds of analyzing the noise I figured out that it was the compressor cycling. Whoops!
Any context regarding "Hell no"? Just curious...
Pressurized, and technically the power is disconnected.
Due to problems in the past with runaway compressors, when I wired this shop I set up relay box with a contactor in the power feed to the compressor. The coil on the contactor is fed through the compressor's pressure switch, and receives it's power from one of my lighting circuits.
The compressor only gets power when the lights are on in the shop, which means it's shut down if I'm not in the shop.
