Joelk
Most people here, probably do, but I bet there are some that don't.
I would guess that the great majority of the general public does not.
If you remove a screw from something and then go to put it back in, do you just start turning the screwdriver clockwise?
That works fine in some materials, but not so well in others. When trying to reinstall a screw into plastic, and similar materials, I initially turn the screw counter clockwise, until I feel it "drop into the thread" and then I turn CW until it is seated.
On soft materials, if you turn CW from the get go, there is a very good chance the screw will try to cut a new set of threads. This will make it turn harder, but more importantly, it will dramatically weaken the threads and will probably eventually result in stripped threads.
I have been using that technique for decades. I don't recall if I read it somewhere(probably), or just figured it out on my own.
I am the primary carpenter/mechanic in my clan, and I instruct all of my mentees to do this. I don't recall any of them ever saying that they already knew this technique, so I don't think it is widely known in the general public.
I am posting about this now, because I just got done doing disassembly/reassembly of a plastic battery charger case and the concept was fresh in my mind.
