3rdgendslmech
Working on a my dodge ram project. I'm not new to body work, but this is my first project I've taken on solo, without some guidance or advice from my dad.
The drivers cab corner got hit and pushed in. I eyed it up.....it's not rusty or creased so I got a stud welder attempted to pull the dent out. It went pretty good or so I thought.....
So what I'm left dealing with now is 1. Hi spots from where I welded the studs and 2. When I removed the studs it pulled the sheet metal off with the studs.
When I get home tonight I'm gonna see if I can get behind the cab corner from inside the cab to see if I can dolly the spots out.
So if push comes to shove, has anyone ever cut a section of a panel out, worked it, then welded it back in place?
