Does an elevated tree house/shed joists need to be pressure treated?
remagenman
Non-pressure treated wood is cheaper and the posts and beams are already pressure treated.
If i cover the joists from direct rain is it necessary to use pressure treated wood for the joists? They'll be 7 feet in the air on top of beams.
Thanks.
jack stand
Lakes Region Maine
Anything that's exposed to regular wetting should be, especially oriented in the flat position.
On the other hand it all should be able to dry easily and tree houses, the tree, and the kids growing up all will probably limit its usefulness after 10 years or so.
Hooked
League City, Texas
It'll be fine as long as it's covered.
We built a raised(18") chicken coup in 1979 using untreated 2x4s covered with fiberglass panels and metal roof. It's withstood multiple hurricanes and storms over the years and still standing. Although, have to say it's starting to show its age. It's been unused for many years but we can't bring ourselves to tear it down since it served us so well all those years. This may be it's last spring. ;)
Firebrick43
West central Indiana
If you bring the siding down to overlap the rim joist untreated will be fine.
I would paint it or treat it with boracare no matter if it’s treated or not to keep the wood bees at bay.
If you have wood peckers you might want to put up a “ceiling” of 29 gauge pole barn liner.
Those no good ^*#+#*
mike93lx
Richmond, VA
I used solely PT to build my tree house. If it stays dry, it shouldn't be necessary, but I didn't feel like the few dollars in savings was worth it
CV428
Personally, I would use PT for anything exposed. But, I can tell you from experience that non-PT lasts a while just fine with no coating. My father helped me build a treehouse about 30 years ago. When they sold the property 16 years later, most of the treehouse was still intact. The floor, which was just 3/4" particle board and OSB, had rotten through in a few areas, but everything else was still there. It somehow survived many New England winters with ridiculous amounts of snow.
With that said... The sun is far less damaging up North than it is in the South. The sun down here in the South absolutely annihilates everything. That same treehouse down here would have been dust in about 3-4 years. I built a PT service deck on the back of my garage two years ago and haven't sealed it yet (Home Depot wood, it keeps oozing sap) and you can see how much it is weather worn already. I built a pergola out of the scrap, sealed it immediately, and the difference is astounding.
As for sheds, if the framing won't be exposed directly to sun and rain, non-PT will be absolutely fine. I use ground contact rated 4x4/6x6 as runners, and Advantech flooring, but otherwise non-PT is acceptable.
The answer will really depend on where you live and the elements it faces, and how exposed it is to those elements.
R
remagenman
Thanks all, decided to go with pressure treated to not deal with the problem of trying to stain or paint.
Didnt even know about Boracare either, thanks.
