Does an SDS-Plus ground rod driver exist?
fr0mastaj
I'm assuming the answer is no, but I figured I'd check...
I have the Bosch Bulldog Extreme which is SDS-plus, and all ground drivers seem to only come in SDS-Max. Also sounds like my Bulldog might not even have enough juice to drive down some rebar then? (To secure some 4x4's for a raised garden bed next season)
Provincial
Near Salem, OR
Do what I do with my gooseneck .680 air hammer: take an old bit that is bigger in diameter than the rod you are driving, cut it off square with a chop saw, slip a piece of hose (I used radiator hose) over it extending a couple of inches beyond the end of the bit to keep the rod from slipping off, and drive it home!
Some rods are threaded for a bronze cap to take the impact without mushrooming the end of the rod. Unless you are driving into difficult conditions, you should be able to use an unthreaded rod.
I drove an eight foot ground rod last month with the gooseneck, and it took all of ten seconds.
F
fr0mastaj
Those appear to be SDS-Max, not plus... unless i am looking at the wrong items?
Yea, i saw that trick on a couple of other websites, sounds like that might be my only option. I wasn't too keen on trying, but since you tried with success, I might go that route. :thumbup:
ekeller
If you are driving ground rods, then there is a easy way. Dig a small hole about 6 inches deep where you want the rod, fill it up with water and start working the rod up and down. It is a easy way to get them in the ground.
tyjoja
albany ore
I've drove a ton of ground rods. The best thing I used was my boss had an old sledge hammer head, about 6 pounds. He welded about a 20" piece of 3/4" black pipe on it, and you would slide the hollow pipe over the ground rod and hold the head in both hands and drive it in like a metal fence post. works slick, but don't swing too much, as you can slide off the rod and rake the hell out of you hand. I also seen some guys use an electric impact drill with the right size deepwell socket and it puts them in quick. Remember call b-4 you dig is usually free in all fifty states, and utilities will come out and locate their stuff in 24 hours. I know from experience, I've hit power, gas, sewer, water cable and phone with ground rods, bob
Darr247
See this site, shows how they use the heater hose. I aslso have an sds plus , and I'm going try this too.
http://www.n4lcd.com/groundrod/
2+ years later and I still find no commercially available SDS+ ground rod driver.
I was going to weld some impact sockets (5/8'', 9/16'', 3/4'') to cut off SDS+ shanks, but that hose trick looks much easier.
I only wonder why the clamp isn't on the cut-off shank instead of on the ground rod?
jkwilson
SW Indiana
This is the no sweat way for sure. Never seen it done any easier. I've put dozens in that way.
Hpozzuoli
Rhode Island
I just googled this stupid ground rod driver for my sds+ and garage journal just came up...go figure. I just ordered the one suggested above on Amazon. It pays to search.
mmelton005
West KY
That method is will get you a few days off if the safety guys at my job (electrical construction). We had a groundman drive a ground rod with that method and it slipped off and he drove it between his thumb and index finger.
Rookie2
Western Pa.
i've drove a ton of ground rods. The best thing i used was my boss had an old sledge hammer head, about 6 pounds. He welded about a 20" piece of 3/4" black pipe on it, and you would slide the hollow pipe over the ground rod and hold the head in both hands and drive it in like a metal fence post. Works slick, but don't swing too much, as you can slide off the rod and rake the hell out of you hand. I also seen some guys use an electric impact drill with the right size deepwell socket and it puts them in quick. Remember call b-4 you dig is usually free in all fifty states, and utilities will come out and locate their stuff in 24 hours. I know from experience, i've hit power, gas, sewer, water cable and phone with ground rods, bob
this !
I helped a 24 YO hoist a 90# electric jack hammer (without a bit) up on his shoulder and
drive a series of ground rods around a cell tower , I love those millennials !
1950mercury
metro detroit
I just put 2 ground rods in at my brother's house. I used a dewalt sds drill with no bit. The rod fit in the drill and it hammered it in the ground no problem. Didn't hurt the drill at all
