Does anyone make 6 point metric line wrenches like this?
bmwpower
I'm realizing that the handle end would make it nice and easy to apply torque.
Hell, even 12 point for that matter...
Fedwrench
Valley of the sun
I don't think anyone does today. Snap on has some new ghey line wrenches with a composite handle and imperial makes those ratcheting line wrenches with a handle..
Why don't you just use a flare crowfoot wrench attached to a 3/8 drive breaker bar? I think that would close to the same size as pictured.
The Muffin Man
Mercer County, NJ
The Toptul European Style wrenches look very similar to the Elora wrenches.
TexasT
Texas
O K , cut the unused side off and weld on a piece of bar/round stock or pipe in any length you desire.
I bet when others see how well they work you could sell them some, too. Just keep extras at home to get top dollar for your 'only' set.
bmwpower
It's not so much the single end, but the handle grip that attracts me to it. Sometime you need the grip for torque AND control. Short flare wrenches on stuck bleeders etc. just plain stink.
Maybe we can get GearWrench to make some? :lol_hitti
swgray
maryland
Snap-On did. I have a 2643 3/4" 12 pt wrench. If you look up Heavy Duty Box Wrenches at McMastr-Carr, it looks like them but with 4 points cut out.
I've a couple from McMaster at work and they are a beefy wrench. Start at 1/2" and go up to 1 1/2".
48548
Phoenix
Here is what I use for better or worse... Also I use the 1/4 body ratchet with a 3/8 head in it, for when I don't have a lot of room... Just a thought for something different.... Also 6 point too!!!!
bmwpower
I may have to get a set of those 1/4" crowsfeet and a small 1/4" breaker bar. Might be a good compromise.
48548
Phoenix
All of the ones I have are 3/8 heads, but with the small fm70a ratchet(3/8 head in 1/4 body), it would be like a 1/4 ratchet.
bmwpower
Aahhhhhhhhhhhh. Looks they they only come in 12 point in 1/4" metric. Dang it.
48548
Phoenix
Hmmmm... The ones I have are snap on and they are in both metric and SAE, but not 1/4, will the bigger ones work? What sizes are you looking for?
bmwpower
For metric lines, like 6mm, 7mm, 8mm or thereabouts.
