Does anyone sell single size butterfly sockets?
atikovi
Suburban Washington DC
Can't loosen tie rod to adjust toe. 17 mm wrench is slipping when I try to loosen it. 16 mm won't fit.
No room to swing an adjustable wrench. Flare nut wrench or crowfoot won't fit. I have a set of these butterfly sockets
but the genius that designed them made them in range of multiple sizes for each. So 17-18 mm is worse than the wrench. Any other ideas?
908Jim
Penetrating Oil and a Pipe Wrench. You'll just round out the hex on those tie rods, spread the wrench jaws, or screw up your anti-slip open end feature. There's a reason every alignment rack I've ever seen has a pipe wrench hanging next to it.
Edit: Pipe wrench to get it loosened and moving, use the hex for the actual adjustment.
fatfillup
Finksburg, Md
Learned about 2 new things on this thread, butterfly sockets and that bolt heater-up'r. :beer:
Knew about the heater-up'r but never seen the butterfly sockets,,,,,,,,,,,,,,,,,,and I have a used tool store :ROFLMAO:
Agree that the pipe wrench or cobra pliers would be my choice to break loose but I do wonder if the Knipex flat jaw plier wrench would work
Hakeem
Chicago
Use 2 open end wrenches. You'll be apply half the torque to each wrench and they won't slip.
Two wrenches stacked right next to each other, doubling the surface area and thereby halving the PSI … so simple I can’t believe I never thought of it. Outstanding contribution.
rust in the eye
Chicagoland
Pipe wrench would have been my go to, then fire. Seems you got it licked.
The tie rod looks to be white metal, aluminum? Threaded a good ways into a steel rod end and jam nut.
Given all the battery chemistry those Tesla folks had to figure you'd think they'd know a thing or two about galvanic corrosion.
@OP Do the next guy a favor and apply some anti-sieze.
