Does anyone use crowfoot wrenches?
SliderXTM
Germany
Re: Does anyone use crawfoot wrenchs?
At work we use crowfoot wrenches for fixing subconstructions for facades, where you cant use a normal nut (no space) on a torque wrench.
va.grouseman
Southern-Central VA.
Was the only tool that would take out an upstream heat sensor on a cobalt catalytic convertor. Clearance was so tight you couldn't squeeze a socket in beside it and the manifold. When you need them, you'll know.
joejeep92
Kansas
I use them on some stuff. Power steering lines going into certain racks. As stated before common rail lines.
Sonny2010
Southeast, Missouri
Some good uses, looks like it defiantly would not be a daily tool. But like someone said you'll know when you need them and it's something I don't have in my tool box.
davethorik
Norka, Ohio
I only have one, a Snap-on 12mm. I use it to unscrew the fitting for the choke cable on my motorcycle's carburetor. It is right up against part of the carburetor body and in a really tight, hard to get to spot for those of us who don't have tiny Japanese hands. A socket won't work in this application and neither will a wrench. The fitting is plastic (!) so pliers are out of the question.
Fedwrench
Valley of the sun
The ratcheting ones are a little on the large side and won't fit some things like on a power steering rack where the high and low pressure fittings are close to each other. Regular flare crowfeet are handy to have. Open ended crowfeet are like a super stubby open end wrench.
GSEninja
I bought my set many years ago and have probably used them 3-4 times since. but when i did use them I was VERY thankful to have them as no other tool would have worked
espyking83
Hell hole of a King Air 200
Depending on your job you might need to use them a lot, very seldom, or never. Working on airplanes I havent used them that much. Usually have to use them on flap actuator shafts and such. Very helpful when nothing else will do the job. Kinda like angle wrenches, you dont really need them until you need them. I wouldnt recommend spending a bunch of money on a set, you may have to grind them down for a smaller profile when you really get into a **** pickle of a jam. They definitely deserve a space in everyones box though.
Darius6t9
I use them on power steering lines all the time. On Nissans, Jeeps (the wranglers have a recall that requires the return line to be replaced) and yesterday a toyota echo.
Richard Cranium
central Washington
I have my second set, I never used my first set and gave them away, then I got a new Matco set in a tool box of tools that I bought at a yard sale. Still have never used them. Rich
AndrewV
Fl
I use them seldomly.
But when you need them, they will save you plenty of time.
2ndGearRubber
Pittsburgh
Check out the crows-feet with a "line wrench" style head.
They can be a bit finicky to get on, but they're great for p/s and transmission lines.
plinker
Northern Wi
Power steering line's (at home mostly), constant use at work with hydraulic's.
Lance-AR
Little Rock, AR
I work primarily on a Porsche 911 where I use a flare nut crowfoot wrench to flush brake fluid and just this weekend used a regular crowfoot wrench to replace an oil pressure sender. I can't picture any other tool which could have worked. When you need them, you really need them.
MFolks
Springfield Mo.
Used mine quite a bit, when I installed Chokes and transformers in large electrical equipment. Could not get a socket in some of those tight spots, but was able to tighten up the 3/8" mounting bolts then with the crowfoot wrenches.
metaldad
nw indiana
i believe the op's question was RATCHETING crowsfeet wrenches.
i have a set, which may be called ratcheting end(?) torque multipliers.
blue point, i can not pull up an image from blue points site. all that shows is chinese gooblygook. not on snap on site, it seems.
the one in my hand is 3/4 box, 12pt, 3/8 drive, ratcheting. blue point #BFCR 2 4 A
jethro29
central delaware
I use mine very often and when you need them YOU NEED THEM.they are priceless to have around.
joejeep92
Kansas
The ratchet kind is the direct quote which at least I took to mean the type used with a ratchet
Jim C.
I have them but I can't recall ever using a single one.
Jim C.
Plombob
Tennessee
I use them not often, but enough that I am glad I bought a set. I am looking to get a set of Metrics. Sometimes a crowsfoot is the only tool that will do the job.
PKile
Fair Oaks, California
They are also useful on common rail fuel line nuts & hard to reach/access brake line nuts on ABS blocks, they also come in handy on brake & clutch master cylinder line nuts.
If you ever have to change a clutch slave cylinder flex hose on an MGB or GT you better have a 15/16" crowfoot plus a 7/16 flarenut crowfoot for the hard line. Doing that job without them is a sure route to madness.
Cheers
Sir Kile of Malfunction Junction
nicksnothereman
In the Mojave
Any good uses for them? The ratchet type. I found a good deal on a set and am thinking about buying them just to have.
If you mean ring end, then no. If you mean open end ratcheting (if they exist) then...maybe. Otherwise, crowsfoot are generally redundant for cars there's probably a couple bolts where it could be necessary but not something I'd buy a "set" of.
I wouldn't pay a premium for ratcheting on a tool I'd rarely use or try not to use. Crowsfoot is a weapon of last resort for me. Maybe get flare crowsfoot if you don't have good flare wrenches.
rlitman
Long Island
I have a consumable electrical part at work. It bolts to a circuit board, in an enclosure, but you must hold the standoff nut while tightening the bolt, or else the board is destroyed. The enclosure prevents you from using any wrench (even a stubby), so a crowsfoot is the ticket to holding the nut.
BTW, another use is with a torque wrench. If you keep the socket perpendicular to the direction of the torque wrench, it does not affect the torque value. This way you can torque things like flare nuts that cannot be torqued with a socket.
MG44
I use them ever once in a while on brakes/ps lines. They won't loosen a rusty 3/8 brake fitting, but work great at reinstalling a new fitting.
abachman
Illinois
When Torqueing the head on a Model A Ford you need one for the nut under the distributor, or else you have to pull the distributor.
MBfreak
MEMBER EMERITUS
Linkoping , Sweden
I use the Hazet 14 and 17 mm quite a lot. They are well made and have an integral bent part that goes up to a 1/2" square drive that is centered over the origo of the nut being tuerned.
Workin on fuel injected MB engines from the sixties theat save a LOT of problems when adjusting the valve mechanism or removing fuel line flare nuts.
Kind of hard to come by, but really useful.
Ola
veks
sgv,ca
I've owned and used these ratcheting wrenches from craftsman that I found them to be so uncomfortable to work with that I gave them away for free. Maybe it was user error, but I felt them to loose around the nut that I thought I would round the corners.
spin_prod_242881101
