As I've said many times, HF has plenty of things that work, just don't plan on buying a Mercedes for the price of a Yugo.
I needed a 4' pipe wrench for one use. I was NOT going to be buying a $200 one. I got the HF one for $35 or so, it worked, I haven't touched it since.
I have an HF pipe bender, works fine.
I have an HF cherry picker, works fine.
I'm going to get an HF press and beef up the beams that bend on them, it'll still be $200 cheaper than the next press, which is no better anyway.
I buy their $.99 hand squeeze clamps when they're on sale. I use them for welding and such, they can and will get screwed, often on the first use. Why in the hell would I buy a $15 clamp for that
I have wilton c clamps for wood working and other things. I have HF c-clamps for when I'm welding. Again, the odds of boogering threads or another part of the clamp is high. Why wreck a good one?
I bought an HF portable "garage" to use as a shed. Is it great? No, but it cost me $150. I have to put a $50 cover on it about once a year. does it compare to a $1000 one? I'm sure not, but it would take me 18 years for that to pay for itself, and I guarantee a tree branch or something would ruin the cover before that.
I bought a 32" lift 2.5 ton jack. Does it have the nice feature to lock the handle for maneuvering it? No. Does it go up easily? Yes. Does it go down smoothly? Yes. Would I buy a $4-800 one just so I could have that vs. the HF one that cost me $100 without it? Hell no.
I needed ratchet straps to haul tree branches and construction debris to the dump. I wanted 12 2" ratchet straps. Obviously, high strength ones aren't needed, just ones to keep things from flying around.
I could buy 12 HF ones for 1/4 the price of good ones, and the tree branches, nails, broken lumber, and concrete will shred them at the same rate as the high dollar ones. Gee, touch choice.
Need to make a wrench fit somewhere? Are you going to grab that $30 Snap-On wrench and torch it to bend it how you need, or are you going to grab that $8 hf wrench set you have stuck in a corner of your box for on occasion such as this?
