Does it matter which which wire goes to the A/C Contactor?
mpire
Florida
I got a quick question.
With my 4 ton Carrier A/C unit, the outside compressor has a contactor that fires up the unit when the signal wire tells it to turn on.
I know its 220 power, so there are two phases going to the contactor.
I don't see any reason that it would make any difference which phase goes on what side of the contactor, but I figured I would ask.
Essentially I am asking if it matters which way the wires are connected.
HVAC Phil
Akron, Ohio
No it doesn't. Most contactors out there, one leg is always hot, with the other leg being broken by the contactor.
M
mpire
Florida
I couldn't figure out why it wasn't starting up so I figured I would ask.
I swapped the wires and it fired off after a few minutes.
Does the fan kick on when the compressor starts, or does it just come on when its needed?
The contactor is less than a year old, it was replaced last year, so I was hoping it wasn't bad.
Wife retreated to the bedroom while I checked everything out. That mini-split was a brilliant purchase!
HVAC Phil
Akron, Ohio
Being it is a carrier, it may bit a bit "over controlled". Most likely there is a timedelay on the low voltage. Also, the cond fan may have a pressure delay as well, runs as headpressure builds. Is there a circuit board?
M
mpire
Florida
I guess there is a circuit board. Its standard stuff. I also have backups I got from the neighbors unit when their compressor died.
I replaced the pull out disconnect and the conduit from the wall with new stuff, and it didn't start back up when I powered it up.
Then I swapped the leads and it fired up.
So IDK, I was just curious if swapping them made any difference, or if it was a delayed start.
Usually it starts right up when I hear the thermostat click on.
