Does my drill press need new bearings?
Goldhawg
Makes a lot of racket, but it drills just fine w/no runout. Listen to the youtube video and let me know what you think...
Thx for your thoughts...
ibedayank
Columbia TN
That thing sounds like its chewing up the gears!!! Better take it apart and fix it hopefully theres no serious damge.
dumper
Oregon
doesn't sound like bearings. More like a loose top cover, maybe the belt hitting something, etc.
larry_g
oregon
I have that same drill and the top cover does make a racket. Pop the top cover off and run it. If the racket is still there then remove the belt and run the motor while using a stick to flex the lower part of the cover, if the noise is still present and you can't nudge the cover away to make it quiet them you got problems on the motor end bearings or balance. If quiet with the belt off and the motor running then turn off the motor and turn the spindle pulley by hand to feel if the bearings are bad or the pulley is hitting the cover tin. One or both of the pulleys could be to far down the shaft hitting the cover, or a dent in the tin, or pulleys to big.
lg
no neat sig line
toolsd
Chickamauga, GA
I agree, there's something else going on there. I'd check and make sure all the sheet metal is tight. Grease up the spline. Take the belt off and run the press, the motor alone should be dead quiet. A pulley could be loose, causing the vibration that is causing the sheet metal to vibrate.
Tools
