texasranger
My wife has gotten into embroidery. By default I'm now the tech support and maintenance crew chief. One routine task involves removing the needle plates that cover the rotary hook and trimmer knives. They are attached by countersunk slotted screws. The needles and presser feet just above prevent use of a normal screwdriver, so I have been using right angle screwdriver, "L" shaped like an Allen wrench. I want something better.
I'm envisioning a cross between a Chapman set https://chapmanmfg.com/collections/all-tools/products/7341-standard-set-bristol-6-flute-set and a rotator ratchet https://www.amazon.com/dp/B000Z9D6EI/?tag=atomicindus08-20
Ultra low profile like the Chapman, with the twist handle to run the screws in and out once loose. Does such a tool exist?
