does this 220v adapter exist?
pfhWJ
looking to get an adapter to go from twist lock 220v(3prong) to 3 prong welder 220v. I know I could make it but would rather buy one due to my lack of electrical skills.
mustangmike6996
Detroit MI
mustangmike6996
Detroit MI
Generally the plug on the welders are Nema 6-50P and the wall will take a Nema 6-50R (P= plug and R= receptacle)
Is your 3 prong plug and wiring setup for the 50 amp rating (sometimes lower like 35 amps, depending on what your machine calls for)
What machine are you planning on running?
rmmiller
Kennewick, WA
I was in need of an adapter as well so I took the opportunity to add mobility by making my adapter 25' long!
P
pfhWJ
lincoln mp 210. spec sheet show input cicuit at 15amps
evintho
Santa Rosa, CA.
The easiest way would be to cut off the 3-prong twist lock and replace it with a NEMA 6-50P. Electrical skills aren't necessary. Strip 1/2" of insulation off each wire, insert into the terminals and tighten screws.......done! The better way would be to do as rmmiller said. Put 25' of extension between the plug and receptacle. I did that too. Now I can move the welder anywhere in my shop. The standard 10' cord didn't work. I found a 25' RV power cord at a garage sale - $10, spliced on a 6-50 plug and receptacle and now I've got 35' of power cord.
BTW, you're gonna need at least a 50a breaker for that Lincoln!
Grrr !!! One of my personal "pet peeves" ! Why do the put a 50A plug on a welder that is not going to draw more than 15-20A ? Personally I would cut the plug off and install a plug that will work with your existing receptacle(s).
It is highly UNLIKELY that you will find one made up. You will have to "roll your own" !
6-50 female cord end
L6-30P (3 wire, 30A, locking)
Great suggestion ! And I found 2/3 of this already made up !
Conntek L6-30P 15-Feet Locking Power Cord - 30A
Bondo
Greenfield, Maine
Ayuh,..... That's been My cure for such problems,....
Picked up a case of those plugs on ebay(Cheap) years ago, 'n have changed all my 240v appliances to 'em,...
Couple of extension cords with 'em too,....
