Does this exist? Air powered vacuum...
BirdMobile
OK...
I want something like a mini-shop-vac, with empty-able container (no bag) for debris, that can **** up metal chips, greasy dirt, etc. without breaking. It needs to have enough suction to pick up small screws and nuts. It needs to be fairly small and light weight. Oh... and it can't be battery powered or need a cord, it MUST work at the end of a 100PSI air hose.
Does it exist? Where do I send my money?
ng8264723
Oakham MA
snap on makes one. I have it it is small and works wellhttp://www.ebay.com/itm/Sunex-SX1000-Dual-Air-Powered-Vacuum-Cleaner-Kit-/330928377029
stratman977
Belle Vernon, PA
I doubt youre going to find one. Those air powered mini vacs use the bag as the filter for the air to pass through. If it had a cup it would need a mini filter to exhaust the air which I don't think would lend well to size and weight.
Fcvapor05
Why does bag vs. container matter? You're just upending it over the garbage can either way..
Why air powered? explosion prof environment? If so, review the design as if the fan blades are made of a ferris metal...
larry_g
oregon
The one rookie2 linked to is a venturi vacuum and has no moving parts.
lg
no neat sig line
Steinmetz
Washington State
Air-powered vacuum cleaners are widely used in the aircraft industry. When I was with the Boeing Co., lots of them were used in the plant for foreign debris removal.
They may be purchased from various aircraft tool suppliers, such as may be found in the pages of "Trade a Plane".
mikehaugen
Northern IL
We have one at work like you describe, except for the size. It mounts to the top of a 55 gallon drum and has 2 large external filters and uses a 1" air hose. The guy uses it to **** up sludge out of a pit. I'm sure they (or somebody) makes a smaller version, perhaps to mount on a 5 gallon bucket? I will get more info on it when I go to work tonight.
Shipfittin
Portsmouth, VA
I use the ones with bags at work and they are amazing at getting into tight areas. I have even sucked water up with them and once I dried the bag out it was fine again.
joecon
They make one with a hose than a bag.I had one and I would remove the
bag and put the hose in a garbage can held there by a spring clamp and it
would shoot the debris in to the can.
MemphisR32
Try a search for explosion proof vacuum's. I have one at work that is used in a paint/solvent lab but its 55 gallons. You also need a lot of airflow to run it.
LennyTheLizard
Southeast MO
The EXair link is a good one.
We actually use these all the time at work (industrial factory).
You could also look up air loading systems for injection machines. Could possibly even find them on Ebay or Craigslist used.
All it is is a venturi that creates vacuum in hose. If you enclose in a bucket or drum you just need an exhaust to let the air out and keep in your debris.
dr_clyde
Holland, MI
I have the little blue point one. It works awesome. If I need to vaccuum up a bunch of nasty stuff I take the bag off and zip tie a shop rag or two on the back. Then just toss the whole mess in the trash.
And the factory bag is washable. I have used it to **** out all the little coolant covered chips inside my cold saw. I just scrubbed it out in the sink and let it air dry.
Danglerb
SoCal
I bought mine from a guy on ebay that sells surplus Magnuson something like that mechanisms with new USA made bags that work with most brands of the smaller ones. Needs a lot of air is an understatement but they are small very handy in some instances.
