Does this Wilton bullet vise look kosher?
txlonghorn1989
I'll be looking at this bullet vise with 4.5" jaws tomorrow. Does it look kosher to you? No swivel lock bolts. Guy says he just misplaced the lockdown bolts and that's probably what he did. But I'm thinking the base of the vise doesn't look to be the same size as the swivel base. Anyone see anything to be concerned about? Thought I'd ask here.
Thanks!
Tex
tarmy
Nor Cal
That thing has been abused…a lot. Unless you like a challenge and he makes you a “you ****” good deal…I would move on. But that is just me. I have two that are in a bit better shape…4196B306-1B10-4EE4-9816-A7257A9EA776.jpeg6F432E42-D6EC-4984-BC8D-53C88DFE2DA5.jpeg
exmaxima1
Midwest
If the hold down bolts are missing, make sure the clamping RING is still there. Bolts are easy to find, but the ring might cost >$50 to procure. With the exception of the handle bar the rest of the vise looks ok---just like it was dragged out of a mud hole. Based on the environment of the pics, it looks like there was a flood. At least it's a Machinist model, not a cheaper Tradesman.
T
txlonghorn1989
exmax Yeah, I was going to check to make sure the clamping ring is there and the centering pin. Do all the bullet models have that centering pin? I've got two 3.5" bullets that both have them so I'm assuming they all do. The handle does look like it's got some serious corrosion but the rest just looks dirty. I am hoping it will clean up good. It is definitely not being offered at a you **** price. Thanks for the heads up!
Mgdoug3
KY
It would have to be pretty cheap for me to be interested in. The handle has a lot of pitting and looks covered in rust. It can be brought back to life but it will take some work.
T
txlonghorn1989
Okay...after me asking, the guy says the inner ring is missing too. I see autopts (GJ member) has one on ebay. I'm trying to find out thru his ebay ad if that includes that centering pin.
Fierljeppen
When you thoroughly inspect the vise, you should find that the inner ring will have a casting no. of 101081, while the outer ring should have the no. 101082 and yes, it does have a center pin. That particular "450S" casting style should have a date-stamp between (1976-1982).
Wilton used this swivel base for the 400S, 450S and the 500S, which is why it may not fit like a glove for each of those models.
You're an experienced vise collector, so I'm not going to coach you with regard to the negotiation other than it has significant market value, unless there's more damage to the vise other than the handle.
T
txlonghorn1989
Mgdoug You think that looks like rust? Could be. I thought it looked like dirt and dust. Irrespective, I told him I'd need him to come down on his asking price. He's going to think about it. I'm not scared of rust or dirt. These don't come up for sale often around here. I imagine someone else will pay his asking price and discover they've got to invest quite a bit more money to have a swivel vise. We shall see.
T
txlonghorn1989
Fierljeppen He's stated now that it is missing the inner ring. I've asked autopts (GJ member who sells some Wilton parts on ebay) if his inner ring includes the centering pin. It isn't visible in the ebay ad pics. The handle is badly pitted if the rest is solid I'd be interested but he's gotta come down to make up for that inner ring. Who knows.
And you explaining Wilton used the same base for 400S, 450S & 500S explains why it looks bigger than the vise base. Appreciate all the feedback!
crguy
SW Washington
I have 2 with the swivel jaw and understand they are 450S models. Neither of them use the center ring in the swivel base, just have 2 bolts with the notched clamps.
gatewaysysop
Arizona
First gut reaction: what lake was this pulled out of?
Not irredeemable, of course, but more work than I'd want to put into it for a keeper. The handle is beat pretty good, makes you wonder about the things you can't see. Speaking of, who knows what lurks under the rust that you might be missing?
Just my $0.02, and full disclosure, Wiltons have never appealed to me. I see people trying to sell their beat-to-****, rattle-canned, missing-swivel-base, 6" Wiltons all the time for more than what a complete 8" Parker or Athol or Prentiss would fetch. To each his own, no judgment, but personally I just don't understand the thirst.
T
txlonghorn1989
Neither do I. Just trying to keep my shop and tool hobby a zero sum gain. I haven't heard back from the guy after asking for a discount. I'm not bothered by the lack of a response. Feel bad if the next guy doesn't realize what he's buying with it needing an inner ring for the swivel base to work. It was priced cheap enough that if everything checked out it's a good deal as a non-swivel vise but it was never a keeper for me.
Thanks everyone for the advice offered!
anndel
Hawaii, USA
Despite the missing pieces others have mentioned, it doesn't look bad at all except for some surface rust.
Davefr
OR
I'm not seeing that at all.
Nor am I. The surface rust is easy to remove. I don't see any cracks, welds, broken ledges. It looks like the end cap is there and the jaws look original and in good shape. The only signs of beating are on the handle but it looks pretty straight. The anvil surface even looks good.
I'd rather buy that one then some of these Krylon "hack job" specials you see.
The base hardware is the only real issue. It could be used as a stationary vise. With complete swivel and cleaned up, you're looking at a $400 vise these days.
exmaxima1
Midwest
The hole in the spindle for the handle looks nearly perfect, so it could mean that only the handle was abused and not really used all that much. You could buy make a new handle from bar stock and some bushings for the ends, or look for a used spindle assembly.
T
txlonghorn1989
Well, things worked out. Went to look at it this morning. The handle has pitting on one end. The seller is a blacksmith, older guy like myself. What looks like rust is really just dust and dirt. He got it free decades ago at a place he was working. He thinks the pitting came from that end of the handle stuck in the ground. You can see at the end of the vise it almost looks like I cleaned it off but that's just from picking it up to load it and the dirt coming off on my hand. Wasn't seized up at all. He included the trailer mount with the vise. Also, said he's going to keep looking for that inner ring and will let me know if he finds it. I appreciate everyone offering up their thoughts on it! This will be a good vise for a long time.IMG_3609.JPG
genog
Silicon Valley
......I don't see any cracks, welds, broken ledges.....
Abused??
I agree with Davefr and others, that ole Wilton looks good to me.
Since it's just dirty, a good soak in Simple Green should clean it up. Even if that were surface rust, Evaporust would fix it.
And, please please don't "Prissy it up"
.....oh well, it's yours to do with what you like.
Nice catch regardless what you paid for it
It will serve you well
Mgdoug3
KY
That goes to show how someone who posts poor pictures doesn't have as many as potential buyers. The seller could have spent 15 minutes to clean up the vises and a lot more people would have been interested.
If the vise was mine, I would probably take it to bare metal and repaint it close to the factory color. It would make the vise look new minus the handle and be good for a lifetime. My Morgan vise I restored, I cut the old rusty handle off, polished up the lead screw and made a new handle. It made the vises look much better.
T
txlonghorn1989
Abused??
I have cleaned up a LOT worse vises than this one to great working order. I like to use BLO (learned that from Drives) on my vises. I'm thinking that's the treatment this one is going to get.
T
txlonghorn1989
I hear you and like genog alluded to..."people can do what they want with their vises" but I am not a big fan of old vises looking like new. I like them BECAUSE they're old and better than new. Why would I want to pretend it's new. Knowing they've already done a generation, or two, maybe even 3, worth of work puts a smile on my face. Again, different strokes for different folks. FYI, he had many potential buyers lined up. I happened to be the first.
Professional Tool User
BC
It's not the end of the world if the swivel base doesn't work properly provided that the vice is otherwise functional. You can still mount the vice unto a bench. As long as you didn't over pay for it, it looks like a fun project to work on.
Lassen Forge
That one is about the same condition as my non-swivel brass jaw when I got it - mine not only cleaned up just fine, it's a daily driver in my shop. Glad you got it, you'll be rather quite happy you did... these bullets are, in fact, pretty bulletproof...
