Does Your Body Hurt Less with a Lift?
kngelv
Detroit, MI
I have a 4-post with a rolling air jack. I got that over a 2-post because my concrete was too thin. Just built a second garage and still use the 4-post. Things are generally more accessible with a 2-post. 4-post is easier to use. Before I got the air jack I used a small airbag jack and jackstands with two rolling jack trays. It was a pain in the *** compared to the air jack. I would strongly advise that you factor in the airjack cost when buying a 4-post lift. Like others I also use my lift for things that a 2-post would not work for so it's a bit more versatile. And yes it has been a pain saver for sure. There is not one person with a lift who will ever wish they did not have one.
James
kbeefy
Harington, Eastern Washington
I love having a lift. I certainly feel better after a day working than when I was doing it on the ground.
I keep a stack of gym floor cushions handy for kneeeling on when positioning the arms. Most unibody cars I can rack on the pinch weld without even kneeling or looking.
20231211_125829.jpg20230102_134214.jpg20230404_122653.jpg20231116_124228.jpg20240411_113010.jpg20231103_141741.jpg0504221011_HDR.jpg
finn
The UP, God's country
Different strokes ...
I'm in my early 70s and stalling on a knee replacement with steroid shots. For my 2 post lift I keep two kneepads at each column. When lifting a vehicle I toss a kneepad down at each lift point. I find that makes a huge difference versus kneeling on bare concrete, or lugging one kneepad around. So no regrets here on 2-post versus 4.
Though I don't always bother, there are lots of potential supports nearby to help me get up (post jacks, ****** jack, rolling stool, etc.) For positioning pads at lift points I usually only need to get down on one knee, a position I can recover from more or less gracefully.
Typical car repair for me is a couple of minutes setting the lift points and then hours working on the vehicle. The wear and tear from the latter activity isn't trivial, and I think would be worse on a 4 post lift for the kind of repairs I do.
I’m about your age, and have both a two post and two four post lifts. I’ll dispute your opinion (although I respect it). Having both, four posts are the only way to go.
I realize I am being redundant., but unless you have both, it’s not likely you can look at the situation objectively
marquess
Those big thick pads are the ticket. I have one on each side.
I have knee pads like that scattered all over my workshop and utility buildings. When my knees hurt enough that I'm thinking twice about walking 50' to the other side of the building to fetch one, I don't want the temptation of skipping a kneepad "just this time".
Those style kneepads are about $8 each in packs of 3 or 4. I have at least a dozen in my largest outbuilding (the one with the lift).
A much younger (late 50s) friend recently gifted me a "balance pad" which is an even thicker better version of a kneepad. Not being a gym rat I had no clue there was such a thing. They are ~3" thick and large. For the lift I just use the standard kneepads for the quick up and down, but for more extended kneeling I use the balance pads.
  • Like
Reactions: ATC
ATC
VA
I need to break down and get some myself. My knees aren't 'bad', but I cannot get on my knees on a hard surface. It's like I don't have kneecaps or something...the pain is intense. Kneeling on grass, carpet, etc....I'm fine. I have kneepads (the kind you strap to your legs), but I don't like using them.
marquess
Both would be best, and if I had a 4 post too I'd for sure use it some smaller percentage of the time. Not an option for me alas, not due to cost so much as limited floor space. The wife says no more outbuildings.
I should also note that most guys my age seem to have some degree of back pain in addition to inevitable bad knees etc. I have been very blessed with (so far) zero back issues. I'm sure my perspective would change if my back as well as my knees hurt when I bent over.
dante2
Central OK
I did something similar with my lift cart. The cart is great for pulling a tire without letting the lift all the way down.
marquess
Excellent point. I often use magnetic pucks for pinch welds. I can usually place those by feel (I get down on one knee on a kneepad but I could bend over enough by crouching a bit and using the car for support) and swing the lift pads under also by feel. I never have to get my face close to the ground. Then I can visually sanity-check placement while standing up.
My only problem with magnetic pucks is remembering to recover them. I had a friends car up on the lift Sunday night. It was late and I was tired and he drove off with all four pucks still attached. Fortunately he recovered all four.
FTG-05
TN
In addition to vehicles, I use my 2 post Atlas lift as adjustable height work bench at times.
BBQ smoker mods; far easier to work standing upright vs squatting on the ground.
Attaching the diesel tank to my farm fuel trailer. Previously, I had added a leaf spring to each spring pack on this trailer. It was far easier to work on with the trailer upside down on the lift vs. it being on the ground right side up.
Installing and de-installing the concrete, lead and steel wheel weights on my tractor (~250 lbs each):
Get the lift, you'll appreciate far longer than remembering the price.
finn
Time to break in a new wife in order to get another shop built!
I have both knee and back pain, but primarily back.
I swear I spend more time looking at cars on the lift than working on them these days.
Off to the big city, ( population 25000) to see the pain Dr. about some Facet block shots Friday. Oh Joy!
Jetfixr320
My Buddy and I share shop space, been wrenching for a long time, both well into Our 50's. We bought a 2 post and a 4 post last year.
We both said that we should have got lifts a long time ago!
I prefer the 2 post lift. Obviously takes a little more effort getting the car lifted. But, definitely more access.
aka Larry
Eastern, NC
I love seeing alternate uses of 2-post lifts.
I've used mine to unloaded a large toolbox off the back of a pick-up, and to even rotate a utility trailer upside down. I used it once to raise the back half of a boat trailer (with the boat on it) ld replace the leaf springs. Most recently I used to move a heavy steel wood stove from my trailer to the shop floor.
new_wood_stove_lift-jpg.2253071
gizardlizard
Madison, WI
I lift every piece of equipment I own with my two post. Two dirt bikes (made adapters for bikes) zero turn tractor, three vehicles, side by side and trailer. Only regret was not having one years ago. I’m old and have zero problems setting the arms. The day I realize I can’t get off the floor, is the day I no longer belong wrenching in the garage.
Smilodon
Titusville, FL
Your car isn't smoking, but your smoker thinks it's a car...
clutchee
TX- Near the Telephone
100% worth it!
3 years ago, wife surprised me at Christmas with it. Having lower back issues and putting off surgery she knew I loved my shop time and crawling around wasn’t helping my back.
Since then, she’s made jokes about how much I use it or have projects on it.
Last year got deal on 4 post from a close friend who passed. It was setup and had old hot rod on it.
Now, I tell everyone, just spend the money on one.
Since buying, buddies needing to “use it” have paid rental in bbq, crown royal, and other donated stuff.
My only rule is noting overnight, if so, they seem to camp out.
pbon
I am slower getting up and down at 61 than 31. Back then it would not bother me to get out from under the car 10 times to get a part or tool, or to set the car in jackstands. I still could, but would rather not. Had a 2 post lift in my last garage and prefer them for their greater under car access, but my current garage has a wood floor so I cannot have a 2 post (I do have 7 steel beams helping support the wood floor). 4 post is still way better than no lift.
kbeefy
That’s a sweet top, where did you find that. I want to build out a simple cargo van but don’t prefer the canvas type.
Found it used on Marketplace, didn't really fit my van but I made it work.
My last campervan was a canvas pop top, this one with real glass windows and real screens is much better.
The original manufactuer was Chefs Campers, I guess they were based in WA but they were before the internet and it's hard to find much info online.
Pop over to my build thread if you want to discuss it further...
campervan build Link
TerryH
Springdale, AR
Absolutely! My old body says I should have bought one decades ago. Many times I just raise it part way and use my rolling mechanics seat. I don't even bend over to clean wheels any more. Also should be noted that we had the transmission out of this car 5 times before I bought the lift. lol... :dunno:
BruceMc
Fairbanks, AK
When I was debating spending the money, I even made a spreadsheet with the different brands, shipping costs, and all the options. I knew to the penny how much it was going to cost me.
Ten years later I couldn't tell you what it cost without digging up the old invoices.
Glemon
NE
I don't know if it makes that big a difference to my body, it is not too hard on me to work lying on my back, but getting up and down sure is less fun than it used to be.
Pain from wrenching is usually from reaching into hard to access places and contorting hands or arms to get there, scraping them getting in or out, leaning over the hood (back) crawling backwards into the footwells to work under the dash.
One huge difference, if you work on crusty old cars you can remove parts without a bunch of rust flakes or PB Blaster dropping in and on your face, hair and eyes.
As I have said before, light, leverage, and access you get with a lift make jobs so much easier, saves a lot of time and effort.IMG_20251007_213448948.jpg
Demon69
Surrey UK
For guys with a lift, does your body hurt less after working on your car? Is the pain a lot less or just a little
It will be a big spend for me, so I am debating if it is worth it.
If youve got the ceiling height, have a think about what sort of work youll be doing and go for it (y)
cpakalolo
For guys with a lift, does your body hurt less after working on your car? Is the pain a lot less or just a little?
Yep, I put one in a week ago. It was expensive because my ceiling was 9.5 feet and I needed 12.5 feet. The garage bay has trusses and the door is in the low end of the trusses. It fits great and is wonderful. I just couldn't get under anymore. I have metal knees and can't kneel.
aggie113
San Antonio, TX
Love my two post lift for working on cars. Like my 4 post lift for storing a car on top and another underneath. Could see loosing the 4 post later when I have a nice shaded area for parking cars outside.
Hal
Vermont
I have a drive on scissor lift. It’s not ideal, because it only goes up four feet, and isn big enough for my pickups. It sure beats rolling around on the floor, and getting up and down for tools. I’m pretty sure the last brake job I did on my pickup was responsible for the onset of my current knee problems.
slomaro3.4
SW Pennsylvania
I just have a lowly maxjax (with an appropriate creeper) and it was 1000% worth the money. Jobs are faster, access is better and I generally get less dirty not rolling around on the ground. If you DiY, have the space and the money get a lift.
ITGuy1998
Northern Alabama
I've had a 4 post lift for a few months now. I'm kicking myself for not getting it 15 years ago. I got two rolling bridge jacks as well. I did the brakes on my son's car last month and it was so freaking easy.
Oil changes? Please. Its almost unbelievable how much nicer it is to remove the freaking splash shields under a car on a lift versus laying on the ground.
Seriously, just do it. Do it now.
