Doing Costco FEIT LED shop light quality assurance for them
driftpin
I bought some of the FEIT LED two-bulb shop lights (#689518) for one garage, installed them, and decided I would get more for another property's two-car garage, but they were sold-out. This was between Thanksgiving and Christmas. I checked the website for store availability, as the online shopping said, "sold-out."
Finally, after New Year's, I saw them now showing a new shipment, I called a local branch to confirm they were in-stock, they were, and I immediately, bought them. I bought an extra luminaire, because at $20/apiece, why-not?
By the time I got to install them, it was the end of January. I threw the two in-place above the front of one garage bay (the rear of the two-car bay has a loft across it, and four, four-bulb flourescent fixtures affixed to the underside). It was late, I decided to do it his morning, the job of hanging the other car bay's two luminares.
This morning, I got to the installation for the second car bay's lighting. The job done, I flipped the switch to power up all-four LED shop lights. I was greeted with three reporting for work, but one luminaire was pulling a " Beetle Bailey" and was sleeping on the job. "Probably the pull-switch is off," I hoped. A tug on the switch produced-nothing. Zip, nada, no illumination. Since it was already screwed to the hanging framework I devised to allow the luminaires to hang below the garage doors, so I would have illumination whether or not the door(s) was (were) open, I tried connecting the 120 volt plug directly to an extension cord, in the possibility that the series-wired female plug it was attached-to might be a dead plug. But, no, still a dead luminaire.
I removed it from the framing from-where it was hung. I went to the phone, and called the closest of five Costcos in the two counties. The helpful female employee, checking their inventory, said, "we have none, and it shows as a discontinued item. We won't be receiving more." Hmmm, this was a problem, as I like all the fixtures to have the same appearance in the same area, and the same light wavelength. I asked her if she could check other stores, and she said, one store had two showing in inventory. I thanked her, and called the other store.
The female employee there checked the computer, said there weren't any showing, and I informed her I had information from another store that there was stock there. She agreed to have someone check the floor, and a few minutes on hold gave me the bad news, none there.
So, I could wait and see if Costco got another shipment from FEIT, look online for another source, or look for another manufacturer's product in a similar style and light wavelength. I was already preparing to return the luminaire, I had the receipt for both of the two shopping trips when I bought four, and then five luminaires. But really, I wanted the durn thing! And working!
I originally had decided that I would return the luminaire for exchange for another, rather than tear-into the thing, trying to fix it. But at this point, I figured, "youv'e got nothing to lose." My wife, who just retired after 42 years as an electrical engineer (same employer!) told me the same thing, when I informed her that there were no luminaires available for exchange. So I opened it up.
Eight phillips screws gained me access to both ends. This is what I found, two wires for two "tombstones" at one end were detached. I had to fuss with one, it didn't want to insert and stay in the stab-in small gauge receptacle. I tried the 120 volt plug-in each time, because it appeared there was only one wire loose. No-go, re-connection #1. Then I saw the loose wire #2, I landed that in-place, and again, no-go. So now, it looked like I was down to something in the circuit board having a faulty component. That was beyond my desire to attempt a fix, or to troubleshoot. i thought, "well, let me see if the 120 volt leads are landed well." And that's when I found detached wire #3. One of the 120 volt leads had a cold solder joint, and was loose, no-longer attached to the printed circuit board. I grabbed my trusty Weller soldering gun and landed it, with a bit of extra solder. Plugging in the extension cord resulted in illumination so, exito as our Spanish-speaking friends would say. It soon was replaced in its place on the brackets I built to allow the lighting of my car bays, whether or not the garage doors were up or down.
I bought nine of the luminaires, in total, including one for a spare if one went bad. I didn't expect that I would get a dead unit upon purchase. I also didn't bother plugging in each before hanging it. Perhaps I should have. Maybe I will, in the future.
So, here are some pics of the lose wires, and the luminaires hung in the garage, below the arc/path of the high-lift garage door. They make a big difference in the illumination of the area, and I hope they last twenty-two years, as the box each was packed-in says. I will be close-to age ninety, so maybe it will be our heirs' problem. The first shot shows how I used the space above the doors for storage of bulky, light items, like Christmas stuff, and unused storage bins. Any lights on the garage ceiling would be blocked by these platforms, or by the garage doors being open. So, my solution was a light framework bolted to the overhead garage door tracks, to hold four two-bulb luminaires below the open overhead garage doors. I used 1" X 3" PT lumber, held in-place by Simpson galvanized steel brackets. I still have to through-bolt the hanging brackets for the wood beams supporting the luminaires.
If you choose to buy these, should they be in-stock again, at Costco, I suggest that you power them to check for illumination before hanging any. While I am mildly-disappointed at having to repair the workmanship, I am glad that they were all things that I could repair on my own.
I will say that my venerable pneumatic Handy Air-Lift motorcycle worktable was a very comfortable place from-which to work while I was hanging these luminaires. It is wide, stable, and tall-enough to access where I needed to-be.
ishiboo
Oshkosh, WI
I have LEDs from Menards... probably 5% have failed in the first 2 years. Very few models from ANY manufacturer last more than a year or two, so getting a replacement is impossible... it's replaced with something like it or they refund the purchase price.
These cheap shop lights are made more for the guy who puts one or two above his workbench or on his 2-car garage, versus us GJ guys who buy a quantity at a time to light a room to OR standards. :)
fowldarr
Coastal Oregon
Not much help to you, but as of last weekend the Eugene (Oregon) Costco still had a stack of them.
Now, I feel like I should go grab a couple of extras now, just in case. I put 4 in my shop recently and they all worked fine and lit right up. Made a huge difference in my shop.
Falcon67
Merkel, TX
You just never know. people fuss about the Lights of America cheapie T8s from Walmart and I have three that are going on 10 years of use. I will say that the LED bulbs we're getting are doing "OK". Of the smaller Edison base units we have lost 2 or 3 well within their claimed life span.
BukitCase
Oregon
I've got about 20 of the Feits in service so far and another couple dozen to go - no failures yet, good to know a fail might be just another "HF fixe" (same prob with an HF skil saw a few months ago)... Steve
matt_i
seems like they sold an awful lot of those...wondering if a "generation 2" is on the way or a competitor's product (?)
redmondjp
Redmond, WA
Thanks for the post - I've been wondering about these, as they disappeared from my local Costco warehouses for quite some time, with a recent reappearance last month.
I ended up picking up several of the single-tube 36" Lithonia LED shop-light fixtures for $13 each on Black Friday at Home Depot. 3000 lumens for $13 which is pretty good. I use one as an automotive worklight, with 6" bungee cords on each end hanging from the hood of my car.
The_Geologist
Baltimore County, MD
I bought a couple of the FEIT's at our Costco about a month ago to replace two decrepit fluorescent fixtures in the garage. The difference was literally like day and night. Even if they only last a couple years, I am grateful to have lights that are bright, even during the winter (unheated, partially insulated garage). I may buy a couple more at some point.
My Old Tools
Hamrick Lake, TX
I have now purchased 36 of the Costco Feit LED fixtures (16 in the old shop, 20 in the new one) with no failures of any kind. I guess anyone can have a bad day.
kbuhagiar
Escondido, CA
Over the course of the last year and a half I have purchased and installed approximately 36 (or maybe more? not sure) of the Costco Feit light fixtures, and have had only one failure.
On that defective unit, one side of LEDs wouldn't light. Took it back to Costco and got a refund on the spot.
I'm happy. :D
LS6 Tommy
Northern NJ
Feit stuff is some of the worst **** I've ever seen. I wouldn't give them a dime for their fixtures...
Tommy
Daedalus
I have 20 in my shop as well. During installation, I dropped 1 from about 12' up onto the concrete below. Had to straighten the sheetmetal out, but the light still worked. So far so good on the lot of 'em.
Being that they're about 14' off the ground, I use wireless outlet switches to control some of them, as I only have 2 switches wired to the ceiling. Works great.
EdT
North Georgia
I have 5 or 6 of the feits going on two years for the first ones installed. They are on all day almost every day and seem to be working fine. Compared to the old t-12s I took out, they make a lot more light.
JimH74
South Central Texas
I bought 15 for my shop area, of which 1 of the 15 was defective-a section in one of the tubes being dark. I also bought an additional 15 for the back area of the building. I have not installed those yet. Much better light than I had, and much less expensive than I had planned on. Very pleased, but to qualify, only about 3 months of usage so far.
LS6 Tommy
Northern NJ
Well, maybe I should try Feit again sometime. If they've improved over what they used to be, they could turn out to be a bargain.
Tommy
Showkey
"MEMBER EMERITUS"
Wausau WI
I have 28 of those fixtures...........over half are 14 months old.........no issues.
Also use the FEIT led PAR 40 can bulbs so far perfect score and most are over two years old. 40-60-100 equivalent LED conventional replacement bulbs often purchased for $1.00 per bulb.
Also use the FEIT drop in LED T8 in special fixtures in a laundry and mud room ..........with 30% reduction in power used and 20% measured FC increase. Again perfect score.
All purchased at Costco with power company instant rebates at huge saving.
tinysparky
I have no idea why they don't have in stock.... ;)
using Tapatalk....In Renton wa, and i can't change my location from the app......
Jeepster04
Funny how people are on the far extremes on these things. I have 10 sitting in my floor waiting to be used for something. Hope they are not ****!
PoorOwner
CA
Funny this post is supposed to talk bad about feit turns out to be more of an endorsement for them.
Homerr
Seattle, WA
I've got 12 Feit shop lights in the garage and another 14 led 4' replacement tubes in my basement for about a year, no issues.
