So I'm going to use the solvent based epoxy coating for my floor. Its currently painted with some bad paint that's already chipping off. So the plan is , power wash all the paint off, degrease, degrease, then here comes the first question:
I'm going to etch, but I also read about diamond grinding being better. Should I etch twice then diamond grind or is that being repetative?
I was going to etch twice to make sure coverage was good either way.
Also, how much does that one packet of etch do? Is that 2 gallons enough to etch once my 400 SF floor? Meaning, if I got 2 kits to do 2 coats, I would have enough since it comes with the kit...
Next question is on clear coat. I've read that it scratches and dulls over time. This garage is going to be used as heavily as any home garage will prob. Grinding, welding, fab work etc. All on cars so it's not like huge metal structures or anything. Also, if I'm putting down 2 coats of epoxy, what benefit does clear provide in terms of chemical resistance etc? I don't really care if it's super glossy, that's just a side benefit. Will it protect the floor more or is it just going to get dull in 6 monthes?
Last question. Anti skid. I'm pretty sure I'm not going to use the rustoleum product as it's aluminum oxide and I'm gonna be on my hands and knees alot working on these cars and I don't want to get all eaten up. So I've looked at shark grip. Either way I was planning on putting it in the last coat of epoxy-either as the last step with flakes or before the clear coat. Does anyone have any pictures of what this stuff looks like applied and how much did you use to make it non skid without oversaturating?
And I think that's it. Also, I'm trying to find the cheapest place online to order this stuff from..any help?
thanks guys!
Matt
thanks guys!
Matt
