OK, i'm getting ready to put down 1109 bondtite clear epoxy on my fresh vct install. i went with 24"x24" a black and white checkerboard theme (armstrong vct).
i rented a floor buffer and went with 80grit screen to surface sand my new vct floor to get it ready for the 1109 clear epoxy. this is where my trouble started.
while sanding the floor the 80 grit screen starts to get clogged (by about 10' of sanding)with bits of black vct dust, then the dust turns to solid little slivers of vct on the 80 grit screen, THEN It SMEARS BLACK INTO THE WHITE VCT!!!
this method may work o.k. on one soild color vct floor ,but it ***** donkey balls for my black and white floor.
what i ended up doing (and what i suggest everyone else to do) is take my 6" random orbital buffer (7424xp porter cable) and got some velcro 100grit pads for it. luckily this seams to be correcting my problem.
It would have been much easier if i would have just started with my trusty 6" orbital, fist do all the white tiles then do all the black tiles. dont make the same mistake i did.
i am taking a break, as i am flat worn out.
