Doodad to cover metal shelving sharp corners?
wahoowad
My big box store shelving has these sharp exposed edges at the top of the vertical supports. Surely there is a plastic corner cap of some sort that will cover them? I thought of splitting some vinyl tubing or something but figured they would get bumped off too easy even if I put some adhesive on them. Duct tape is too thin. Any suggestions?
whateg01
doo dah, kansas, usa
Mine came with molded plastic caps but I like those that tall grass posted. I typically have used rubber vacuum hose and a glop of rtv.
CraigStu
Blacksburg, Va
Paint a couple of coats of liquid electrical tape on them. Or get the similar stuff in cans meant for dipping tool handles in.
mike93lx
Richmond, VA
Even the plastic caps that come with them pop off easily.
I'd grab a grinder and round it off.
Between all the sharp edges and thing particle board shelves, I stopped using those and went to heavier duty "industrial" shelving (pallet rack style) with plywood shelves. Much more durable
bwringer
Indianapolis
Yah, windlace or edging will do ya just fine.
Or maybe... just spitballin' here... maybe this is the excuse you've been waiting for to buy a 3D printer.
AffableCurmudgeon
Triad Area NC
A piece of pool noddle, about twice the height of the protruding angle iron edge, with a zip tie through it, should cover and cushion the exposed edge. The zip tie, through the noodle and the top hole on the angle iron, should keep it in place.
walta
Dutzow Missouri
Sooner or later any padding will get in the way, be dislodged and leave you bleeding.
Cover the shelf with plywood thick enough to cover the vertical support.
Scribe a mark on the vertical supports even with the top of the shelf. Remove the shelf. Cut (angle grinder, saber saw or hack saw) about 1/16 below the line. Paint. Reinstall the shelf.
Walta
Monza Harry
Windsor ON
To stick on your cap of choice try some "Windshield urethane" as it is pretty sticky stuff but expensive. A cheaper choice is "Gorilla Snot" [weather strip adhesive,] this has that nick name for a reason! Harry
And some other caps Canadians can't always see the "atomic ind." links sorry if already posted.
Angle Iron L Shaped Rubber Foot Pads Covers for Shelving 10 Pack https://www.amazon.ca/dp/B07X1GVLXQ?tag=atomicindus04-20
dogdog
Best if you can get the things like post #2 if not, a rubber hose from any automotive store and some silly cone would work as well. You know split that 3/8 hose in half and glue it onto that corner.
niget2002
Josephine, TX
I replaced the crappy MDF shelves that they come with with 3/4" plywood. Then I 3d printed little caps that screwed into the plywood.
You'll want to replace the shelves anyways as the MDF they come with sag within a year.
gahrajmahal
Cincinnati, Ohio
I did this for my garage door angle irons once I realized when I was carrying my grandson out to the car his head was higher than mine. It wasn’t close, but boy the blood drained from my body when I thought I could have bonked his head there. They are now too big to carry and might get big enough they might hit it themselves, so the pool noodles stay.
Miss the Pontiacs
Saskatchewan Canada
I had some sharp or head level (Grandson) angle brackets on my table saw. I was scared he might hurt himself or take out an eye. I simply used some cut down pvc pipe to cover and soften a potential blow. Still might hurt but you still have to learn to be aware of your surroundings.
Fixr
SW VA
As far as I know, there is no edge molding, split fuel hose, windlace or anything of the kind that will really stick to those uprights. Either cut and smooth the uprights down below flush with the shelves, or build up the shelves to be taller than the uprights. Every other possible solution is more work for less return. Just simplicate and get it done.
The Cobbler
cut them off, or, how wide is the angle? looks like a 2x cut to fit front to back would serve as a stopper for stuff falling over the edge as well as protecting injury from the corners
hampster
I saw some 3D printed caps once on Etsy. They weren't an exact fit, as they were designed for Whalen metal shelving which is slightly different. But close enough you could use it as a source of inspiration.
whitesco
Pittsburgh, PA (ish)
Or if you already have a 3D printer, maybe a CNC router and a bandsaw to cut L shaped hardwood trim pieces and rout a groove to fit the edges.
whitesco
On the 65-73 Mustangs in the interior where the "B" pillar pinch weld is they use windlace to cover it. It is vinyl with wire inside to hold the shape when you press it on & pinch it tight.
I used to use this on the sheet metal edges of the door behind the panel when working on windows, latches, etc of said vintage Mustangs
onewheat
Knoxville, TN
Are you sure that the horizontal metal for that shelf isn't upside down? I have shelves that look just like that and the shelf metal is flush with the top of the post and the particleboard sitting on the metal sits just above all of the metal - thus protecting you from the sharp corners.
Something about that just looks 'off'.
whateg01
Look at the horizontal member. The pins or studs or whatever you'd call them are roughly the same distance from the top and bottom. How would flipping them do anything? I think I might have the same shelves. They are inexpensive. The vertical pieces are actually 2 halves, each about 3 feet long, that are held together by a plastic sleeve. Mine came with plastic caps to cover the ends. And the particle board on mine sits lower than the edge of the metal, like the picture shows
onewheat
Knoxville, TN
They do look like the same distance from the edge in the picture. I'm out of town, so I can't look at mine, but I was wondering if there was maybe a lip on the inside of the horizontal piece that is on the bottom instead of the top. They could have changed the design - mine is 10+ years old - but has the same 2-piece vertical posts but my top corners are definitely not exposed like that.
Dan in Pasadena
Pasadena, CA
Was just thumbing through the thread titles and came across this one mostly because of the use of the word “Doodad” - I haven’t looked but I doubt that’s actually a word in the dictionary, is it?
In Spanish we’d use the very slang word “chingadera” - which; if you translated it would be “Effing thing” even though in common usage it isn’t intended to be quite so harsh. More like the stupid thing or damn thing.
I assume there are similar terms in other languages too. Maybe this subject needs a thread of its own?
outinthetallgrass
onewheat
Knoxville, TN
This is how my shelf is. There are two distinct sides on the horizontal pieces. If these were installed upside down, the shelf definitely wouldn't fit correctly and may leave the exposed corner. There is a lip for the wood to sit on when installed like this - the other way, there is not.
Coach James
Sandhills of North Carolina
I just looked at mine and the metal shelves are oriented like this also. The wood is slightly above the top of the corner posts as well.
Coach
